  #46
Old 10-08-2012, 09:18 PM
phil32 phil32 is offline
Rep: 68 Posts: 46
PAR,
I have my transom made and finishing 3 coats of epoxy on it . My question is after setting it in PB should I cover the entire piece and around the sides with several layers of biax a then begin tabbing the sides. or the reverse.
Best regards
Phil
  #47
Old 10-08-2012, 09:25 PM
Rep: 68 Posts: 46
PAR,
Sorry should have incl some pics
90 Ozark Deck Boat rebuild-comp-005.jpg  90 Ozark Deck Boat rebuild-comp-006.jpg
  #48
Old 10-08-2012, 11:51 PM
Yacht Designer/Builder
Rep: 3967 Posts: 17,962
No you don't have to cover the transom, the biax is just the "bridge", which we call tabbing, between it and the hull shell or other structural elements.
  #49
Old 10-19-2012, 10:29 PM
Rep: 68 Posts: 46
PAR
Would you kindly take a look at the repair to the transom and see if you feel this is adaquate. I have 6 layers of tabbing on the inside and outside corners and 3 full layers covering the entirety.
Hope this finds you well.
Best regards,
Phil
90 Ozark Deck Boat rebuild-motor-mount-002.jpg  90 Ozark Deck Boat rebuild-motor-mount-003.jpg  90 Ozark Deck Boat rebuild-motor-mount-004.jpg
  #50
Old 10-20-2012, 12:25 AM
The gel coat should have been ground back to mat, before the new laminate went on, but I'll bet it'll hold up fine anyway. I'd also like to see the edges have fabric wrapped over them to tie both sides together. A few layers will do. Now you have a bunch of fairing to do. Keep us posted . . .
  #51
Old 10-24-2012, 06:35 PM
Rep: 68 Posts: 46
PAR,
Finally got her back on the trailer. I have wrapped the edges with 3 continuous pieces tying in each side. Is this what you had in mind.
Best regards
Phil
90 Ozark Deck Boat rebuild-flip-001.jpg  90 Ozark Deck Boat rebuild-flip-003.jpg  90 Ozark Deck Boat rebuild-trlr-002.jpg
90 Ozark Deck Boat rebuild-trlr-005.jpg  90 Ozark Deck Boat rebuild-trlr-006.jpg  90 Ozark Deck Boat rebuild-trlr-007.jpg
  #52
Old 10-24-2012, 07:43 PM
Yep, you've learned well Grasshopper . . . now lets see her get wet.
  #53
Old 10-26-2012, 03:25 PM
Rep: 68 Posts: 46
PAR,
Thanks for the compliment, keeps me motivated. Im getting ready to buy the deck materials. My local yard has APA Exterior 3/8 Fir $25.75 and yellow pine $19.97 Dont mind spending the money is the fir a better choice?
Best regards
Phil
  #54
Old 10-26-2012, 03:36 PM
You have to be careful about APA grades. There's only one that's half way good and it's "Exterior", not "Exposure 1", or "Exposure 1, Exterior". Even this stuff is marginal at best, mostly because it lacks a reasonable veneer count and internal defects are quite high. The pine will finish a lot better than the fir.
  #55
Old 10-26-2012, 03:48 PM
Rep: 68 Posts: 46
PAR
Thank you for the reply. I made sure to ask if it was APA Exterior 1. No one here carry Marine grade 3/8 however, they do have 1/2 but that would set it above the top of the hull flange.
Phil
  #56
Old 10-26-2012, 06:00 PM
MDO is available in 3/8" and is a slightly better grade than Exterior.
  #57
Old 10-26-2012, 06:33 PM
Rep: 68 Posts: 46
PAR
I thought there were problems with MDO holding a screw
  #58
Old 10-26-2012, 08:04 PM
The problem with all relatively thin APA sheets, is they don't have enough veneers. Both 3/8" and 1/2" will have only three veneers. MDO is all Douglas fir. Exterior can use a few other species.
  #59
Old 12-18-2016, 01:27 PM
Oscar002 Oscar002 is offline
Rep: 10 Posts: 4
Phil,
I am new to the site, and I am about to undertake a very similar project to this one. Do you still have any pics of the lay out of the deck support system you used and how did you like the results?
  #60
Old 12-18-2016, 05:56 PM
ondarvr ondarvr is online now
Rep: 506 Posts: 1,342
Phil was last here around 2.5 years ago, so he may not respond, you may need to start your own thread.
New Project Boat Rebuild Ike Boatbuilding 73 08-07-2013
09:32 PM
Rebuild boat georgiahemi Boat Design 1 03-28-2011
04:14 PM
Rebuild the old boat John FunBoat Fiberglass and Composite Boat Building 2 01-22-2010
09:03 AM
pontoon rebuild deck question crush Boat Design 5 04-22-2007
06:08 PM
Help for Deck rebuild for 27' Ericson David Torrence Boat Design 2 08-21-2004
07:47 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
