Old 08-01-2008, 08:02 PM
StabbyJoe89 StabbyJoe89 is offline
Rep: 10 Posts: 2
6 foot by 8 foot homemade barrel raft
Hello to everyone. Me and my friends are currently building a barrel raft. It seems to be a popular design from what i gather online. We're using 4 plastic 55 gallon drums to keep afloat. To keep the barrels in place we're using 1inx4inx8ft slats of pressure treated lumber. The flooring will be 2 sheets of 3/4th inch 4ft by 8ft plywood. The catch is that we're cutting them into 2 3ft by 8ft pieces and attaching them together to make a 6ft by 8ft flooring. We're also throwing in some galvanized steel wire to keep the barrels from slipping out. According to stuff I've looked up it our sink weight is 1,800lbs (4drums x 55gal x 8.3lbs). Our 4 person combined weight is 700lbs, 50 lbs in supplies, 100lbs for the 4 drums, I'm hoping 300-350lbs for all the lumber+plywood. Total: 1,200lbs?
Attaching a sketch.
brown is the 1in x 4in x 8ft pressure treated lumber
background is the plywood
the dotted line is the connection of the 2 3ft by 8ft pieces
green is the galvanized steel wire
blue is the barrels
Thanks for reading. Just wondering... will it float!? Also can we sail it in the Chicago River? or in Lake Michigan? Is it allowed? None of us have a boating license and it won't be registered. Thanks!!!
http://img294.imageshack.us/img294/8...tsketchmh9.jpg
Old 08-01-2008, 10:47 PM
kengrome kengrome is offline
Rep: 287 Posts: 719
Bad design. At maximum load your hulls (barrels) should be submerged no more than about 1/3 their depth -- or at the very most 1/2. You're way beyond this with only 4 barrels, so you need more.
Kenneth Grome
40 foot concorde reinholdt Powerboats 0 03-24-2008 03:54 PM
Plywood and Plastic Barrel Creek Raft barrelfinder Boatbuilding 4 04-16-2007 03:00 AM
Cp for 26 foot sailboat Greybarn Sailboats 2 06-23-2006 03:14 PM
What exactly is square foot Yolinda K. Boat Design 6 04-13-2005 02:23 AM
14 foot Fletcher Boat Design 1 08-12-2001 01:59 PM
