Old 01-02-2011, 05:56 PM
crazycarl7 crazycarl7 is offline
Rep: 10 Posts: 2
1987 25 C-Hawk stringer question (water seeping out of the fiberglass)
Question in regards to my 87 c-hawk PH redo. I had to replace most of the stringers under the deck due to rot. The wood was nothing but mulch. One of the stringers on the starbord side (under the pilothouse) was comletely rotten as well. i cut out some of the floor in the pilot house to replace that stringer. The center stringer was pretty solid but a little damp. The same with the port side. It has been about 30 degrees here in Maryland for the past few weeks and now its the 50's. I went outside and looked under the pilothouse today it looked like the center and port side stringers were wet (outside of fiberglass was wet). Water was actually seeping out of the fiberglass and puddling in the center of the hull. I know that they were damp, but was suprised by this. When I hit on them they feel solid and the look solid. Has anyone ever seen this? If so how do I fix. Cutting out the entire pilot house is out of the question. I have all the new stringers ready to be installed in the stern of the boat but I want to fix this first. Can i drill holes and dry them out somehow? is there a chemical that i can put on them? should I sister new wood to them ( If i do this, it will be hard to fibergless them in)? any ideas?? Thanks in advance
1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8077.jpg  1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_7673.jpg  1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8063.jpg
1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8064.jpg  1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8065.jpg  1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8066.jpg
1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8067.jpg  1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8068.jpg  1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8069.jpg
1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8071.jpg  1987 25 C-Hawk stringer question (water seeping out of the fiberglass)-img_8072.jpg
Old 01-07-2011, 09:24 AM
Rep: 10 Posts: 2
86 viewers and 0 replys? wow
Stringer question CSX Boatbuilding 6 07-26-2010 04:24 PM
1987 Bayliner Transom/Stringer Modification kj2008 Fiberglass and Composite Boat Building 44 06-06-2008 04:25 PM
Another stringer replacement question mongo75 Fiberglass and Composite Boat Building 4 02-21-2008 10:51 AM
Second Stringer question pairomedicsfish Fiberglass and Composite Boat Building 6 09-22-2006 12:47 PM
Fixing Water Under Stringer gotoith Fiberglass and Composite Boat Building 12 05-21-2006 11:21 PM
