Old 09-09-2015, 05:25 PM
gregkuiper gregkuiper is offline
Rep: 33 Posts: 68
19' Quintana Panga/Runabout
Just finished my 12' Bahia Panga and am now starting on my 19' Quintana Panga plans that I just ordered from spirainternational.com.
I'll be taking the basic plans and making some slight modifications to get a boat that will be nice for cruising the harbor as well as fishing and possibly overnighting at Catalina Island now and then.
I'm using the base 19' Quintana Panga and will be making some modification along the lines of the classic Redwing and Downeaster Lobster boat style
Boat will have wrap around seating in the stern with a small cabin up front for a head and berths.
I'll be hanging the outboard off the back with an extended outboard bracket.
Old 09-10-2015, 09:43 AM
LP's Avatar
LP LP is offline
Flying Boatman
Rep: 584 Posts: 1,367
Nice project.
One suggestion that will make your thread more readable to others. Post you pictures as thumbnails or reduce the size of the photos...or both. These large photos really screw with readability of the thread. I finally stopped following your other build because it was a pain to read text that would run off of the screen because of the size of your photos.
Just my two cents.
LP ----------
Bless the open minded people of the world. LP
"Your mother cheated. That's why you look like a plumber." Ender
Old 09-13-2015, 12:13 AM
Rep: 33 Posts: 68
This is the 12 footer I just finished. The 19 footer will have pretty much the same shape/lines with a cabin up front.
Old 09-25-2015, 09:16 PM
Rep: 33 Posts: 68
Started lofting today. Frames will be 8 inches wider then original plans so that I can get an 8'6" width. Built the first frame and still have a nice Vee with the extra four inches on each side. I used 10x2.5" deck screws on my last boat and am very happy with how easy they are to drive with the star heads and their corrosion resistance. I'm not going to epoxy any of the frames until I have them all finished and sitting on the strongback. I'm going to put in some additional detail to the frame and try to get as close to perfect as I can on the measurments.
Old 09-27-2015, 07:02 PM
Rep: 33 Posts: 68
Decided that I need to build a full lofting table since my measurements weren't accurate enough only doing one half at a time.
Today I fixed the first frame and finished the second frame. I'm really happy with how wide the interior will be. On the future frames, I'm going to divert a little from the plans on the heights so that I get more of a Lobster Boat feel. The plans start the rise at about the fourth frame. I'm going to extend that out to about the sixth frame.
Old 08-28-2016, 06:39 PM
Jmckissick Jmckissick is offline
Quintana
Greg do you have any photos of the Quintana
Old 08-29-2016, 11:54 AM
Rep: 33 Posts: 68
Hi, didn't realize the server that was hosting my photos is down. Here is a YouTube link with some videos from July. Since then I have finished glassing the bottom and have faired, primed, sanded and ready to flip it.
https://www.youtube.com/watch?v=Q7E1rF76jDo
Old 08-29-2016, 11:57 AM
Rep: 33 Posts: 68
I should also mention that I lengthened the boat to 22' from the original 19' and have widened the beam to 8'9". I did the beam stretch by adding to the width of the sheer clamp and chine log. What this does is give you a little less deadrise and a nice sharp bow entry.
Old 04-14-2017, 12:55 PM
Rep: 33 Posts: 68
Progress
Hi all,
Flipped the boat last weekend and have started working on the interior. Since this photo I have started working on the gunwales, run conduit and created a template for the sole. Boat length without the outboard pod is 21'9" and the beam is 8'6"
Old 04-20-2017, 02:23 PM
Rep: 33 Posts: 68
Just added one yesterday. The server that my old ones were on no longer exists.
19' Panga/Runabout gregkuiper Fiberglass and Composite Boat Building 0 09-09-2015
05:12 PM
Panga 31+ joeshark Boat Design 4 06-27-2008
01:38 AM
panga 22 captain gary Boat Design 12 07-25-2005
05:05 PM
Panga Seed Boat Design 1 08-18-2004
12:27 PM
Panga Seed Wooden Boat Building and Restoration 0 07-09-2004
12:50 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
