Old 07-06-2009, 10:57 AM
johnnyfire johnnyfire is offline
Rep: 10 Posts: 3
16ft 1969 Newman transom repair.
Here we go another money pit although my first boat I ended up with a great engine package but the transom is junk. Heres some pics of what I have done so far. I only plan to get 2 or 3 years out of this repair. Then I will upgrade to an aluminum hull.
whole boat>
outside view>
inside view>
inside bilge>
after lookin at the stringers though the bilge they arent in the best shape but they will hold for atleast the next year or two till i get my aluminum hull from my buddy.
ok floors open insult away all!!!!
Old 07-06-2009, 12:22 PM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 592 Posts: 2,800
I would strongly recommend to use the "search" function here (as on every other, similar site). There are years to read if you just look for "transom repair"
There are hundreds of good comments and real valuable advice. Though not all contibutors have the same level of knowledge, and sometimes even wrong statements are found (as on every other, similar site). If you look for the advice given by "PAR" you are on the safe side.
Regards
Richard
Fortior est qui se quam qui fortissima vincit Moenia.
Old 07-06-2009, 01:25 PM
Rep: 494 Posts: 3,843
You can repair that with two layers of 3/4" AC plywood. Put 3/4oz mat between it and between layers. Put two on the outside face and maybe four on the edges. Polyester resin works fine. It lasts for many years.
Old 07-06-2009, 04:38 PM
Rep: 1133 Posts: 4,723
You'll need to cut back the sole a bit, possibly the ends of the stringers to get at the hull shell along the bottom of the transom. The new core needs to be tabbed to the hull shell, not the sole. Of course the sole is patched and "blended" back into the transom, but this it's a structural tabbing, just to "clean" up the interior. You need to remove the remnants of the plywood on the outer skin too. You want to bond to 'glass.
Currently you have enough room to tab 2/3's of the way around the transom perimeter, but haven't any access to the hull shell below the sole. Open this area up, clean out the rotten wood, grind back to good 'glass and bond in a new core.
Now you see why I prefer to remove the outer skin. Much less work, it ( the transom) needs repair and paint anyway and you don't have to go crazy cutting around all the structure on the inside.
transom repair cflood Boatbuilding 9 07-09-2009 11:02 AM
Transom repair renovatio Boatbuilding 3 07-09-2009 10:56 AM
16ft Tahiti (1969) pickled Powerboats 2 08-01-2008 01:18 AM
Transom Repair dblanton Outboards 0 10-22-2007 08:31 AM
transom repair andrew Fiberglass and Composite Boat Building 4 01-25-2005 10:38 PM
