| 1:1 scale foam milling I'm interested in criticisms of milling a 1:1 scale model of a 40" multi-hull in foam and finishing it off in glass (rather than turning it into a mould). I have access to a 5 axis mill that can handle objects this size and although the waste of foam is obvious, the ability to CAD a lot of the fit-out seems to outweigh this. |
| A plywood jig with foam and glass layup would be a lot simpler than what you are proposing. And you only need a 3 axis router to get a great fit ![]() |
| Thanks for that. I'm not sure a 3 axis router will give me the level of internal detail I'm after but happy to be told otherwise. |
Here are some photos: ![]() ![]() ![]() That was all on a 19' Center Console, but you get the basic idea. The same methods can be used with plywood instead of foam. |
| I supply foam, and given the fact that you would like a structural foam, cross linked PVC foam being the cheapest option, I am affraid that the cost of the foam alone will scare you off. I once had this request before from a customer, who has the opportunity to do this kind of job. I calculated nicely what the amount of foam for the hull would cost, and he nearly fainted.
| Herman, Can you give us some indication of the cost of cross linked PVC foam? A figure per cubic meter would be of interest to me. Thanks Splint |
| Sorry to be pedantic. "..I'm interested in criticisms of milling a 1:1 scale model of a 40" multi-hull.." How can a 1:1 be at a scale, other than 1:1?? ie full size. |
When you buy in substantial quantities you should calculate some 2500€ per m³, sheets of course would be twice that (but you need blocks). In PMI foam you could calculate four times that price (but no need for Rohacell as a mould). Estimate 0,7 to 0,8 m³ per meter length as a minimum for such narrow hulls. A mono would have quite a bit more. So, have another beer (better 12 of them) before the mill starts to drill that stuff into scrap. Might be worth to think about the hint pamarine gave. Regards Richard |
| Well, is it a 40" ( inch ) model or a 40' ( foot ) model? |
| Foam strips around a set of frames? Harly any waste, so what you pay is what ends up in the boat, not being thrown away as dust...
| new 5 AXIS milling plant | KND | Marketplace | 3 | 01-05-2008 03:28 PM |
| New 5 AXIS milling plant | KND | Powerboats | 0 | 11-29-2007 02:30 AM |
| 5-axis milling machine | mechatics | Fiberglass and Composite Boat Building | 3 | 02-21-2005 04:15 PM |
| about 5-axis milling machine | mechatics | Software | 0 | 02-20-2005 11:44 AM |
| Milling Earl's Fir | Bob Smalser | Materials | 4 | 12-08-2003 02:07 PM |
