Old 10-05-2009, 01:17 AM
Boston's Avatar
Boston Boston is offline
Rep: 1360 Posts: 3,257
The Woodworking Thread
I thought Ild set up a thread for woodworking projects that; although they may not be directly associated with boat building, are no less deserving of an honorable mention
my latest build is a Victorian remodel job I landed earlier in the year so this one is my latest
its all laminated solid white oak except the 8/4 deck planks ( not plywood veneer ) and if you look carefully in the last pict you can just make out some of the laminated sections were there edges are exposed
the panels are all floating and its all built in sections so as be able to breath without splitting anything
the deck is set up on WO sleepers over the framing so as to maintain similar expansion and contraction rates between the deck and the skirts on the sides
everything is mortice and tenon with oak pins except for the decking
I'll be getting the steps done Monday, Tuesday and start assembling the hand rails soon after
in this next you can see how I used twin tenons to make up for the shallow mortises were the panels float in the frame
I wanted the tenons to be of a consistent depth so I cut in a twin at each style and rail
there is some glue preventing a good view of the tenon's but the mortises are clear enough
dry fitting the frames before I started getting silly with glue
in that last on the lower left you can see where I accidentally cut off a tenon, so I just mortised both sides and Ill use a feather tenon to get a good connection
Old 10-05-2009, 08:36 AM
Bamby Bamby is offline
Rep: 700 Posts: 5
Boston that is some fine looking work you've performed there. I've always loved oak myself though I usually use a clear finish that ends up in a honey finish that makes the beautiful graining of the wood stand out for admiration. Personalty thats too fine and elaborate work to be outside in the weather IMO but to each their own.
Old 10-06-2009, 01:37 AM
masalai masalai is online now
masalai
Rep: 1630 Posts: 7,322
Boston, keep posting, That is some BEAUTIFUL work... Congratulations... When you start on your boat, make sure you take lots and lots of photographs - My picture record to date is 336 items with the Nikon coolpix S3, and the Canon shots (3840 x 2160) add a further 55 images... so buy yourself a cheap external terrabyte hard disk (my WD elements was AU$149) so should be sub $100 for you...
This - - "You must spread some Reputation around before giving it to Boston again." becomes sooo frustration, and it is well deserved, alas I cannot deliver
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 10-06-2009, 05:57 AM
Boston's Avatar
ah its the thought that counts M
no worries
Bambi I also would have preferred a different stain but I gotta go with that the customer wants
I just hope they change the color of the house soon
or better yet just strip the paint completely and leave it natural brick
they have a list a mile long of changes they want so one thing at a time though
this house never had any curb appeal and some form of deck or another had been screwed up two or three times in the last few years
no clue what the original was but the tile disaster that was there must have been some kind of joke cause it was sure funny looking what with all the tiles falling off and the lump in the middle were they plywood had buckled
not sure I have any picts of what I replaced but
dam
something had to happen
oh hey
I have tentatively decided to do a test bed for the old elco idea
a 22' Zimmer runabout
Ive found complete plans and Ill build it as specified except I'll retrofit the engine compartment with a steam power plant and boiler
but Ill leave in all the design elements supporting a typical diesel engine just in case the steam system is inadequate
I dont want to find out the steam is not going to work and be stuck with a hull that is built around that instead of able to take a conventional power plant
thing looks pretty straight forward and should be an easy build
I have plenty of white oak and am thinking of planking it with poplar
cheap and easy
and then putting a skin of cherry trimmed in teak and ebony
since I have a bunch of cherry and teak laying round anyway
I just need to set up a tent in the back yard and Im good to go
anyway Ill take some shots as it moves along
but not so sure I want to do it in the winter
glue is such a pain in the ass when its cold out and I dont want to have to run a heater in there
best
B
I also have a 350 gas engine in a crate out back
but that might be overpowering this thing
not sure what it calls for
Thread titles blaze_125 Forum Questions and Suggestions 2 04-06-2009 08:17 AM
Gardening thread! clodgo Open Discussion: All Things Boats & Boating 24 03-20-2008 08:43 AM
Please help with this thread Trevlyns Powerboats 0 04-01-2007 03:48 PM
Any aussies in this thread? rhino Open Discussion: All Things Boats & Boating 19 09-04-2006 07:17 AM
