Old 05-09-2010, 01:59 AM
payam payam is offline
Rep: 10 Posts: 0
what is transom ?
Hi
I want to know what transom is
can you help me ?
please give me some pictures about it ?
Old 05-09-2010, 02:07 AM
capt littlelegs capt littlelegs is offline
Rep: -67 Posts: 237
Originally Posted by payam View Post
Hi
can you help me ?
The transom is the straight back end of the boat where the rudder or outboard motor is often fixed on to.
Old 05-09-2010, 02:47 AM
Obsession Obsession is offline
Rep: 35 Posts: 68
Maybe it would be fun to have a thread of transom talk
What kind of boat are you thinking about payam?
On sterdrive boats the transom is between 2" and 2 1/4" (51mm-57mm) thick. Over the last 30 years, on fiberglass production boats it's typically built with a plywood core laminated between fiberglass skins. This is one of the most common problems with 15+ year old boats as water often gets in over time and rots the wood core.
I always thought 12 degrees was standard transom angle, but I see in the mercruiser book that 13 degrees is the standard transom angle for fitting mercruiser sterndrives (with 10 to 16 acceptable)
Larger outboard boats typically have increased support (added transom knees) to handle the torque of the outboards solely supported there. Inboard powered boats have a thinner transom since the propulsion force isn't coming into play there.
Another interesting thing would be a thread of all the atypical transom designs over the years. On powerboats I've played on, in the 70's we often saw the central area popped back a little bit; in the 80's we saw the reverse where pods to the sides were sometimes popped back; now we have the ever present integrated swim platform where the sheer comes down at the transom and the swim platform provides a molded in horizontal surface to add stiffness to the transom.
In the broader world beyond what I'm playing with, you also have transoms which are raked forward, transoms that are not immersed but where the centerline continues to above the waterline before terminating...
Old 05-09-2010, 02:58 AM
Rep: -67 Posts: 237
I feel strangely tired all of a sudden!
Old 05-09-2010, 08:44 AM
apex1
Maybe it would be fun to have a thread of transom talk ...
If there is one topic handled to death on this forum, then it is definetively the transom and transom repairs in all possible ways.
Old 05-10-2010, 10:46 AM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1004 Posts: 582
Hi
can you help me ?
There is an article on Sailing Stuff about that. - Don't click the link, it's not serious - So, No . . . . to those pics . .
Don't know for sure if you are joking though. It could be a language problem, as you started this topic on the ‘‘Boat Design’’ forums you could be serious, so here also this link and if you're land based then it could be this.
For serious answers (last two links) to simple questions you can use Google. Or is it blocked in Iran?
Good Luck!
Angel
Old 05-11-2010, 03:28 AM
Youngsalt's Avatar
Youngsalt Youngsalt is offline
Rep: 10 Posts: 6
this transom talk is trangressing in to a tiresome tangle
Old 05-11-2010, 05:57 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,354
also this from wikipedia:
Hoyt
Old 05-11-2010, 06:25 AM
Rep: 35 Posts: 68
A true boating enthusiast could hang an outboard on that transom...
This comes to mind:
http://www.boatdesign.net/gallery/sh...puser/909/sl/s
Old 05-11-2010, 10:06 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,169
and then one has the broad African type transom as sported by this lady...
Wynand
A scatterling of Africa
Old 05-11-2010, 03:34 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
A transom is the butt of the boat where you bolt your outboard to.
That's not a big butt Wynand. Wanna play one up's
Note the heavy stringers there to support the structure...
Regards
Fanie
Water ! Just gimme water !
Old 05-11-2010, 05:24 PM
hoytedow's Avatar
Resistor
The stringers put me in mind of a Texas tornado.
Hoyt
Old 05-11-2010, 05:28 PM
hoytedow's Avatar
Resistor
2 minute point on video: http://www.youtube.com/watch?v=OVdTpaq4Odg
Hoyt
transom Winner bassboat Fiberglass and Composite Boat Building 3 02-13-2009 10:29 PM
transom shelbygone Boatbuilding 10 07-08-2006 06:10 PM
Transom Reinforcement teel27 Fiberglass and Composite Boat Building 4 07-08-2006 06:05 PM
Transom Support James Francis Fiberglass and Composite Boat Building 2 06-09-2006 07:24 PM
transom bammy the bass Fiberglass and Composite Boat Building 1 09-27-2004 05:03 PM
