Old 07-18-2011, 12:31 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,834
I don't have grounding system I don't have earth system. I don't have yellow and green wire. How do I check the pin in the marina plugs earth is earthing.
Old 07-18-2011, 01:12 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1416 Posts: 2,246
Hang a metal object attached to a wire in the water and measure between the wire and the ground pin then.
Old 07-18-2011, 01:21 PM
Frosty's Avatar
Ah--Ok -- thanks very much.
Old 07-20-2011, 11:11 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
We had a current leak (on dry land) a few years ago. We had some (probably unrelated) problem with water pump relay and while measuring noticed the control line had a continous 70V in it. The pressure switch and the relay are in separate buildings. After some more measuring and searching the culprit turned out to be an old lead shielded cable (elsewhere in the system) that had started leaking.
It's not likely to find that sort of cable anymore though.
Lurvio
Hopefully creating something useful, since 1983.
wire diagrams razzor72 Boat Design 2 03-30-2010 06:26 PM
Marine Wire Mark Emaus Electrical Systems 44 10-17-2009 07:11 AM
Another please help my wire my boat. stef1-11 Electrical Systems 6 01-07-2009 04:00 AM
good source for wire jk0529 OnBoard Electronics & Controls 2 03-24-2008 09:07 PM
Welding Wire Arrowmarine Metal Boat Building 2 09-03-2004 01:01 AM
