| he didn't write very well
__________________ liberty ships were beautiful |
| recommended capeks, war with the newts i was half way through before i realized how much i was enjoying the story A Canticle for Leibowitz Vonnegut's Galapagos
| that was good too and farmer
| the foundation series
| e gads sounds like we like a lot of the same writers ok back onto subject Quote:
__________________ I am skeptical of the deniers diatribe |
| SILVER SPRING, Maryland -- Scientists analyzing measurements taken in the deep ocean around the globe over the past two decades find a warming trend that contributes to sea level rise, especially around Antarctica. Greenhouse gases in the atmosphere, such as carbon dioxide, cause heating of the Earth. Over the past few decades, at least 80 percent of this heat energy has gone into the ocean, warming it in the process. "Previous studies have shown that the upper ocean is warming, but our analysis determines how much additional heat the deep ocean is storing from warming observed all the way to the ocean floor," said Sarah Purkey, an oceanographer at the University of Washington and lead author of the study. This study shows that the deep ocean – below about 3,300 feet – is taking up about 16 percent of what the upper ocean is absorbing. The authors note that there are several possible causes for this deep warming: a shift in Southern Ocean winds, a change in the density of what is called Antarctic Bottom Water, or how quickly that bottom water is formed near the Antarctic, where it sinks to fill the deepest, coldest portions of the ocean around much of the globe. The scientists found the strongest deep warming around Antarctica, weakening with distance from its source as it spreads around the globe. While the temperature increases are small (about 0.03°C per decade in the deep Southern Ocean, less elsewhere), the large volume of the ocean over which they are found and the high capacity of water to absorb heat means that this warming accounts for a huge amount of energy storage. If this deep ocean heating were going into the atmosphere instead – a physical impossibility – it would be warming at a rate of about 3°C (over 5°F) per decade. "A warming Earth causes sea level rise in two ways," said Gregory Johnson, a NOAA oceanographer at the Pacific Marine Environmental Laboratory in Seattle, and the study's co-author. "The warming heats the ocean, causing it to expand, and melts continental ice, adding water to the ocean. The expansion and added water both cause the sea to encroach on the land." Sea level has been rising at around 3 mm (1/8 of a inch) per year on average since 1993, with about half of that caused by ocean thermal expansion and the other half because of additional water added to the ocean, mostly from melting continental ice. Purkey and Johnson note that deep warming of the Southern Ocean accounts for about 1.2 mm (about 1/20th of an inch) per year of the sea level rise around Antarctica in the past few decades. The highly accurate deep-ocean temperature observations used in this study come from ship-based instruments that measure conductivity through salinity, temperature and depth. These measurements were taken on a series of hydrographic surveys of the global ocean in the 1990s through the World Ocean Circulation Experiment and in the 2000s in support of the Climate Variability program. These surveys are now coordinated by the international Global Ship-based Hydrographic Investigations Program. The study, "Warming of Global Abyssal and Deep Southern Ocean Waters between the 1990s and 2000s: Contributions to Global Heat and Sea Level Rise Budgets," authored by Sarah G. Purkey and Gregory C. Johnson, will be published in an upcoming edition of the Journal of Climate.
| Kuwait - The Kuwait Diving Team announced on Sunday, based on a comprehensive survery of the territorial waters, death of 90 percent of the coral reefs surrounding the Kuwaiti shores. Head of the Kuwait Diving Team Walid Al-Fadhel said in a statement to KUNA, "this requires quick action by the competent authorities to find out the real causes, as well as solutions." He also called on frequent goers to these marine natural sites to refrain from any action that may inflict damage in the reefs or kill the creatures co-existing with them. The comprehensive survey, conducted by the team, included the major locations of coral reefs 50 miles along the shores and 70 km from the southern coast borders, with depths ranging from 1-13 meters. The combing covered Um Al-Maradim, Kheiran, Ras Al-Zor, Garouh, Um Diera, Teyler, Kubbar and Oraifjan with the result of 90 percent of "bleaching" of the coral reef. At the begining of noticing this phenomenon, he added, dead fish were found floating on the water surface, or laying between the corals, yet not anymore. Al-Fadhel said that the team does not know the causes for this disaster, but it is either a natural or human, which requires the competent authorities, whether global or local, to examine and prepare accurate studies. He noted that the diving team proceeded to contact several local and international companies (interested in this matter) and send the necessary reports with some samples of sites affected for study. Furthermore, he pointed out that the team had highlighted through awareness campaigns the necessity of protecting the coral reefs and raising tons of waste and nets off them. Al-Fadhel revealed an initiative to offset the environmental destruction of coral reefs by expanding the reserves of Kuwait Jaber marine sites, rehabilitation of coral reefs and coral farming, in coordination with French experts. He then expressed readiness of his team to coordinate and cooperate with scientific sectors to follow up on this phenomenon and seek to rehabilitate these locations. (KUNA)
| and one more if I may By Cain Burdeau, Seth Borenstein, Associated Press NEW ORLEANS—Far beneath the surface of the Gulf of Mexico, deeper than divers can go, scientists say they are finding oil from the busted BP well on the sea's muddy and mysterious bottom. Oil at least two inches thick was found Sunday night and Monday morning about a mile beneath the surface. Under it was a layer of dead shrimp and other small animals, said University of Georgia researcher Samantha Joye, speaking from the helm of a research vessel in the Gulf. The latest findings show that while the federal government initially proclaimed much of the spilled oil gone, now it's not so clear. At these depths, the ocean is a cold and dark world. Yet scientists say that even though it may be out of sight, oil found there could do significant harm to the strange creatures that dwell in the depths—tube worms, tiny crustaceans and mollusks, single-cell organisms and Halloween-scary fish with bulging eyes and skeletal frames. "I expected to find oil on the sea floor," Joye said Monday morning in a ship-to-shore telephone interview. "I did not expect to find this much. I didn't expect to find layers two inches thick. It's weird the stuff we found last night. Some of it was really dense and thick." Joye said 10 of her 14 samples showed visible oil, including all the ones taken north of the busted well. She found oil on the sea floor as far as 80 miles away from the site of the spill. "It's kind of like having a blizzard where the snow comes in and covers everything," Joye said. And the look of the oil, its state of degradation, the way it settled on freshly dead animals all made it unlikely that the crude was from the millions of gallons of oil that naturally seep into the Gulf from the sea bottom each year, she said. Later this week, the oil will be tested for the chemical fingerprints that would conclusively link it to the BP spill. "It has to be a recent event," Joye said. "There's still pieces of warm bodies there." Since the well was capped on July 15 after some 200 million gallons flowed into the Gulf, there have been signs of resilience on the surface and the shore. Sheens have disappeared, while some marshlands have shoots of green. This seeming recovery is likely a result of massive amounts of chemical dispersants, warm waters and a Gulf that is used to degrading massive amounts of oil, scientists say. Animal deaths also are far short of worst-case scenarios. But at the same time, a massive invisible plume of oil has been found under the surface, shifting scientists' concerns from what can be easily seen to what can't be. For Ian MacDonald, a Florida State University biological oceanographer who wasn't part of Joye's team, the latest findings confirm that government assessments about how much oil remains—especially a report on the subject by the National Oceanic and Atmospheric Administration in August—were too optimistic. The oil "did not disappear," he said. "It sank."
| How much will the C of G change? | Gene H | Diesel Engines | 6 | 03-02-2007 10:30 AM |
| Somebody Please help with impeller change! | SC Hartwell | Outboards | 2 | 01-14-2007 12:44 PM |
| Change My Skeg? | mcody2005 | Boat Design | 1 | 11-05-2006 11:45 PM |
| How about a change of pace? | Handtool | Fiberglass and Composite Boat Building | 11 | 09-14-2006 08:42 AM |
| Career Change | preaser | Education | 2 | 10-07-2004 10:29 AM |
