#9286
| The question about the real cooling amount caused by aerosols remains as one of the greatest uncertainties to stablish how much of the warming can be attributed to CO2. The complex influence of atmospheric aerosols on the climate system and the influence of humans on aerosols are among the key uncertainties in the understanding recent climate change. But not only aerosols caused by humans have to be put into the equation, as there are several natural causes of aerosols in the atmosphere, as per example those created by airborne bacteria and the african dust, on top of the sea salt and the short lived volcanic activity ones. The Gunnar Myhre paper cited previously reports that a careful study of satellite data show the assumed cooling effect of aerosols in the atmosphere to be significantly less than previously estimated. Unfortunately, the assumed greater cooling has been used in climate models for years. In such models, the global-mean warming is determined by the balance of the radiative forcings—warming by greenhouse gases balanced against cooling by aerosols. Since a greater cooling effect has been used in climate models, the result has been to credit CO2 with a larger warming effect than it really has. The absorption frequencies of CO2 are already saturated, meaning that the atmosphere already captures close to 100% of the radiation at those frequencies. Consequently, as the level of CO2 in the atmosphere increases, the rise in temperature for a given increase in CO2 becomes smaller. This sorely limits the amount of warming further increases in CO2 can engender. Because CO2 on its own cannot account for the observed temperature rise in the past century, climate modelers assume that linkages exist between CO2 and other climate influences, mainly water vapor. To compensate for the missing “forcing,” models are tuned to include a certain amount of extra warming linked to carbon dioxide levels—extra warming that comes from unestablished feedback mechanisms who's existence is simply assumed. Aerosol cooling and climate sensitivity in the models must balance each other in order to match historical conditions. Since the climate warmed slightly last century the amount of warming must have exceeded the amount of cooling. A large aerosol cooling, therefore, implies a correspondingly large climate sensitivity. Conversely, reduced aerosol cooling implies lower GHG warming, which in turn implies lower model sensitivity. The upshot of this is that sensitivity values used in models for the past quarter of a century have been set too high. Using elevated sensitivity settings has significant implications for model predictions of future global temperature increases. The low-end value of model sensitivity used by the IPCC is 2°C. Using this value results, naturally, in the lowest predictions for future temperature increases. According to the Myhre paper previous values for aerosol cooling are too high—by as much as 40 percent—implying the IPCC's model sensitivity settings are too high also. Discrepancies between recent satellite observations and the values needed to make climate models work right have vexed modelers. “A reliable quantification of the aerosol radiative forcing is essential to understand climate change,” states Johannes Quaas of the Max Planck Institute for Meteorology in Hamburg, Germany. Writing in the same issue of Science at which Myhre's work was published, Dr. Quaas continued, “however, a large part of the discrepancy has remained unexplained.” With a systematic set of sensitivity studies, Myhre explains most of the remainder of the discrepancy. His paper shows that with a consistent data set of anthropogenic aerosol distributions and properties, the data-based and model-based approaches converge.
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
#9287
| Here a couple of interesting images from the MACC project, showing the forecast of the optical depth at 550 nm of some of the anthropogenic and natural caused aerosols, as to date sept 05, 2010. We can realize the difficulty of the problem of dealing with aerosols, as their distribution is greatly irregular, not like CO2 which is a well mixed gas. http://www.gmes-atmosphere.eu/ MACC takes as its input comprehensive sets of satellite data from many tens of instruments supplying information on atmospheric dynamics, thermodynamics and composition, made available by space agencies and institutions with which the agencies collaborate to produce retrieved data products. The satellite data are supplemented by in-situ data from meteorological networks and a limited amount of data from networks providing in-situ measurements of atmospheric composition. Data are processed to provide a range of products related to climate forcing, air quality, stratospheric ozone, UV radiation at the earth’s surface and resources for solar power generation. Additional in-situ data are used for validating the processing systems and the products they supply. MACC operates a value-adding chain which extracts information from as wide a range of observing systems as possible and combines the information in a set of data and graphical products that have more complete spatial and temporal coverage and are more readily applicable than the data provided directly by the observing systems.
#9288
the graph you presented contains the relevant data, the bit about aerosols is well established and like so many other aspects of climate studies seems to be escaping you once again for the readers further edification Quote:
#9289
| Once again your posts are a simple game of find the flaw. generally its a no brainer like this last were you are simply ignoring your own graph rather than admit that right in front of your eyes is the data which you claim does not exist its also indicative of a small mind when you descend into a litany of petty abuse for anyone who disagrees with you, personally I find it humorously entertaining but obviously your behavior has driven several noted posters from the thread. Obviously your position cant tolerate debate and so you react rather than reason. Pity really as if you would take a moment and actually listen to what some of these folks are telling you you might just actually learn something. There is an axiom that fits well in this regard a mind is like a parachute |
#9290
| I see.... It's totally useless to try to bring you to think and debate with a minimum of logic. You just insist in behaving like a perfect idiot, posting once and again information you do not understand at all and taking undue conclusions from it, just because of your sickly compulsion to apparent a cleverliness and understanding you do not have at all. Totally idiotic, as said. Not surprising, though. ![]() Here you have something for you to entertain yourself instead of coming here to post nonsense: http://www.addictinggames.com/theidiottest.html Even you being an idiot, don't worry because you can try as many times as you want. ![]()
#9291
| It is very hard to achieve consensus on climate change when there is so much malice and misinformation to strive against. Those of us that are genuinely interested in addressing the issues of climate change need to work together more closely while strengthening our resolve to overcome the prevalent malice and deceit.
__________________ In the Quest for Development and Application of Hybrid Technology we must turn to the Penguin for Inspiration. |
#9292
| There is indeed a lot of malice and deception coming in fusillades from the Church of Warmnotology.
__________________ Hoyt The TITANIC sank because it had a hole in it(still does). Submarine Tom You just can't put too much info on your patterns. DGreenwood |
#9293
| boston, it's way better to be a perfect idiot than just a so so idiot be the best you can
__________________ liberty ships were beautiful |
#9294
| the temp keeps rising and the ice keeps melting, hey but don't worry about it we're terraforming the planet for our replacements nature really doesn't give a rats ass about us, we're only special in our own minds
#9295
| It's hard to win a debate upon global warming when you try to pit science against pure unbridled hatred. Hatred always wins because the conscientious opponents of global warming have no means of quelling the hatred that consumes the hearts and minds of their opponents.
#9296
| they are also the ones against social programs untill they need one, then they're only for the ones they need
#9297
#9298
| i don't want to worship it, i just want to be able to live with it (the way it is) if we change it, nature will happily get rid of us and go on to something else
#9299
not sure if this will paste but I'll give it a try Quote:
what makes it even more interesting is it looks like he is raising 4 to a power by a factor of 40 which places these odds within the bounds of near impossibility and for those folks just reading along means the chances of Guillermo being right are almost nil and the chances of him being wrong are almost infinite I'd write it out but there's just to many zero's involved with all my love and admiration B hmmmm thats one in 40000000000000000000000000000000000000000 chance Guillermo is correct when he claims there is no correlation between CO2 and temp so the real question is how many of the readers would take those odds in a card game |
#9300
| Yawn!
| How much will the C of G change? | Gene H | Diesel Engines | 6 | 03-02-2007 11:30 AM |
| Somebody Please help with impeller change! | SC Hartwell | Outboards | 2 | 01-14-2007 01:44 PM |
| Change My Skeg? | mcody2005 | Boat Design | 1 | 11-06-2006 12:45 AM |
| How about a change of pace? | Handtool | Fiberglass and Composite Boat Building | 11 | 09-14-2006 09:42 AM |
| Career Change | preaser | Education | 2 | 10-07-2004 11:29 AM |
