#4636
Now, you may have some other information from which you make your statement that there was cooling --I know that I've read it elsewhere-- I'm just saying that this from quote you cannot make that conclusion with any confidence. |
#4637
And as I'm sure you've noticed, the fact that fruitcakes believe something doesn't automatically make it false. Otherwise, the simple fact that some AGW skeptics believe it's a deliberate, world-wide conspiracy would be enough in itself to prove it true. ![]() Yes, some fruitcakes have attached themselves to the subject--on both sides. But the average scientist, politician, activist or everyday citizen who believes AGW is a threat isn't just saying it as part of some agenda to destroy progress or repress humanity. I have no respect and little tolerance for the average conspiracy buff, no matter which particular conspiracy he happens to be pushing at the moment.
__________________ There's a difference between keeping an open mind, and letting the wind whistle between your ears... |
#4638
| Troy...how did you come to believe that GW must be true? Did you come to that conclusion after exhausting all possibilities from both sides without any bias or favouritism reaching such conclusion using the scientific method? You would be from out of space if you did that. Humans choose a side BEFORE based on association with values that can be completely unrelated, stored in their subconscious and then scramble for "proof" to support their choice. All this is of course not a conscious decision, yet it is inescapable and such is how the brain works take it or lump it. It is rather simple and there is ample literature to support this concepts that go several decades back. Certainly not a new discovery. Similarly I chose to oppose GW alarmist for exactly the same reasons. Association to values I have stored and I use for my own choices. The difference perhaps lays in the fact that I know that such is how my mind works and I have made a conscious effort to weed out the values that do not serve me and use only the one I want. So I can say that my choice, when still based on the same principle we all use, is based on values I have made a conscious effort in choosing. My proposition, and lets be clear, NOT A CRITICISM, since you until now had no choice in the matter, is that anyone that has chosen a side over another must fist understand why he did so. A set of values that have lived in your mind since before age 10 and that have shaped all your decisions for a long time without allowing your own intellect or logic to have a say. So perhaps the fervour or blindness exhibit by some in spite of overwhelming evidence can be explained simply because the person can not accept the other side to be right or it will contradict his core values. However said core values in most cases are completely obscured to the conscious mind. A fascinating subject and certainly at the root of a lot of unnecessary disagreements.
__________________ There's only one corner of the universe you can be certain of improving, and that's your own self. Aldous Huxley |
#4639
I'm not sure you can say the same. Anyone who believes that the evidence on his side is "overwhelming," when the vast majority of mainstream scientists have come to the opposite conclusion, is much more invested than I am and has a blind spot of his own. Maybe you should be considering your own irrational attachment to one side of the argument, instead of making snide remarks about the disfunctionality of those who adhere to the other side..... If you really believe all that mumbo-jumbo, pseudo-psychological bs you're spouting about 'core values' that are obscured to the conscious mind, maybe it's time you shut up about mine--and started trying to get in touch with your own.
#4640
| Most people I meet in real life seem to believe that man is driving climate change and I have yet to find one of them that is confident enough to explain it beyond some very basic questioning. Mostly it comes down to the media told me its true so I believe it, they definitely don't understand it.
__________________ Never trust someone who can't say 'I was wrong'. |
#4641
| Polynomial Cointegration Tests of the Anthropogenic Theory of Global Warming Michael Beenstock1 and Yaniv Reingewertz, Department of Economics, The Hebrew University, Mount Scopus, Israel. http://economics.huji.ac.il/facultye...aper091209.pdf Abstract: We use statistical methods designed for nonstationary time series to test the anthropogenic theory of global warming (AGW). This theory predicts that an increase in atmospheric greenhouse gas concentrations increases global temperature permanently. Specifically, the methodology of polynomial cointegration is used to test AGW when global temperature and solar irradiance are stationary in 1st differences, whereas greenhouse gas forcings (CO2, CH4 and N2O) are stationary in 2nd differences. We show that although greenhouse gas forcings share a common stochastic trend, this trend is empirically independent of the stochastic trend in temperature and solar irradiance. Therefore, greenhouse gas forcings, global temperature and solar irradiance are not polynomially cointegrated, and AGW is refuted. Although we reject AGW, we find that greenhouse gas forcings have a temporary effect on global temperature. Because the greenhouse effect is temporary rather than permanent, predictions of significant global warming in the 21st century by IPCC are not supported by the data." More: "We show that when these shortcomings are corrected, there is no evidence relating global warming in the 20th century to the level of greenhouse gases in the long run. We show that although greenhouse gases share a common stochastic trend, this "greenhouse trend" is not cointegrated with global temperature and solar irradiance. Therefore greenhouse gas forcings do not polynomially cointegrate with global temperature and solar irradiance. Consequently, the putative evidence in favor of the anthropogenic theory of global warming turns out to be spurious. Although we do not find permanent effects of greenhouse gas forcings on global temperature, we find that they have temporary, or short-term, effects. This means that an increase in CO2 emissions only has a temporary warming effect. We show that previous investigators have confused the temporary with the permanent. This means, crucially, that a doubling of greenhouse gas forcings does not permanently increase global temperature. The policy implications of this temporary greenhouse effect are obviously much less serious than had the effect been permanent." Cheers. |
#4642
| Don't buy a used hybrid from Phil Jones.
__________________ Hoyt Lighting is very selective and will not strike crap. Wynand N http://www.genocidewatch.org/southafrica.html http://www.saabc.net/ |
#4643
| I see the PR campaign is alive and well I did notice that only G was even remotely attempting to introduce any science into the conversation although in every case so far its been frighteningly easy to show that science to be generated by the agnotists and on a most amateur level at that. maybe once he posts the solar data he suggested we will be able to confirm the solar data already presented ![]() simple reality is that the animosity expressed concerning science in general would not likely exist if in that science supported the deniers views. Then Im sure the Deniers would be pointing out the majority of data in support of there cause. Its not, It doesn't and the deniers are pissed off at the science for so obviously leaving them flat footed and without a leg to stand on. Guess the only thing to do is attack science or anyone who just happens to have a background in the sciences makes it a lot easier to play a PR game rather than concentrate on the data my two cents we now return you to your normally scheduled disinformation campaign love B
__________________ I am skeptical of the deniers diatribe |
#4644
| This is what passes for science? The scientist Phil Jones admitted to the fraud, so what more is there to say. He even tried to keep the Medieval Warming Period out of the records, thereby hiding science and distorting history, all to control the weak-minded among us. Come towards the light. This is for Boston. Some PR actually is true. http://www.americanthinker.com/2010/...es_confes.html
#4645
#4646
In Italy there was a say many years ago that went a bit like this ... Say it is raining right? The average person would say "It is raining, thieving government!" Everything is the fault of the government even the rain. This is said as a joke yet fits a universal way of thinking. If a person has a model of who is at fault for what he sees as wrong, he will seek a way to blame that side for anything under the sun. The GW hypothesis fits a certain model that fits a lot of people not only greenies and it is those who will automatically align with GW as soon as the news comes up with the steaming stacks in the background. It is so fitting that the very background of every single news snippet to do with so called GW has a background that is a bold face lie. Smokestacks emitting water vapour. A lie. A fabrication. A publicity stunt. INTENTIONAL. PREMEDITATED. USED AT SATURATION. Yet no one seems to get it. It's pollution because the overpaid idiot reading head is telling you so. When it fits your preconcieved notions your logic is impaired to a point that one can make an elephant dissapear using a crane, and no one will notice. Furthermore you will probably attract the ire of the anti-psichology....and to think we are in the year 2010, not 1810
#4647
| Al Gore Seems To Have No Idea What ClimateGate Is All About Sunday 13 December 2009 - email to someone printer friendly Quote:
#4648
we are talking the same thing, really. Achieving statistical significance in scientific terms is much more likely for longer periods, and much less likely for shorter periods. In this case the lack of statistical significance is due to the short period of time, in the own words of Prof. Jones. Cheers. |
#4649
| Prof. Jones finally admitted the relevance of the MWP.
#4650
the rest is typically a blatant slander campaign whats funny is that when you point out the obvious frauds the deniers go nuts claiming that somehow we should be debating the phony information. At least G gives up on ones clearly shown to be snake oil salesman. I think G is pretty good at digging up some anomalous data and has presented several interesting points. Hoyt at least has a good sense of humor but some of the stuff that gets posted is so obviously PR propaganda its almost funny its so bad whatever I stepped back from it a while ago no sense trying to make sense of nonsense cheers B
| How much will the C of G change? | Gene H | Diesel Engines | 6 | 03-02-2007 11:30 AM |
| Somebody Please help with impeller change! | SC Hartwell | Outboards | 2 | 01-14-2007 01:44 PM |
| Change My Skeg? | mcody2005 | Boat Design | 1 | 11-06-2006 12:45 AM |
| How about a change of pace? | Handtool | Fiberglass and Composite Boat Building | 11 | 09-14-2006 09:42 AM |
| Career Change | preaser | Education | 2 | 10-07-2004 11:29 AM |
