#1966
| really I hope that boat is in a safe place and stays dry this time watch for sneaker waves if you go out to her be safe B |
#1967
| Well, as said earlier; Some areas/ seas; warmer, more evaporation. colder areas will get more water/ snow... And the transport of air with high humidity from warmer areas to colder areas (my place..). will cause more weather/ winds. Happened earlier too, but we can probably try to adjust to the fact that we'll get more. Not always too comfortable. About boats in a safe place... We received 15-20 cm of (extremely) heavy snow right here.... Large areas nearby have received 60-100 cm... In the last 24 hours... Even here that can be considered pretty extreme. Yesterday, I discovered that i now suddenly have a small sub.... Well, as long as the wind continues to come from the eastern direction, the boat's in a pretty safe place.... ![]()
__________________ KnutS "it's dark and we're wearing sunglasses" |
#1968
| Thanks Mas & Boston. Good old "Marie" is safely moored at the Club Naval de Pontevedra, which is in the River Lerez at the tip end of the Ria de Pontevedra, so well protected. Here you have a camera in real time where to watch her: http://www.clubnavalpontevedra.com/ptz/camara.htm She's the one with green covers for sails, top of roof and front of wheelhouse, as well as 4 orange liferings on top of it. Cheers.
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
#1969
I hope your small sub is as safe as Marie at least.About weather: I don't see how eastern winds can bring warm and humid air to your place to then cold down and precipitate in snow form... Cheers.
#1970
Not a too pleasant job to raise (even) a small boat if that weather strikes... (temperature from 0 to -10 deg C, a stormy kinda wind and snowflakes sized like wetted kittens flying in horizontal streaks through the air). Tomorrow..... maybe....![]()
#1971
| its but cold here these last few days although the previous few were in the 70s and with rain |
#1972
| Turns out, I was wrong, there have been a helluwalotofweather......it seems... Just a dinghy, GRP, double hull. Went very easy to fish/ fix the ropes to the pullerts(?). Get the boat to float with the gunwale just flush with the water, throw in a big pump, tilt the boat a little, watch the gunwale rise to "safe" position - Coffee.... time.... Then if floated "nicely" just to get the water out of the double hull, opened a small hole, just large enoug to squeeze in a hose. Let another (much) smaller pump run for 2 hours.. It did rise further, but very slowly... too slowly.... much too slowly....then it occured to me.... hey? can it be that I'm only circulating the Sea of Skagerak here...? Boat was not stable, funny and interesting, but not stable.... When water is around freezing point, some people are a bit reluctant to go for a trip in a boat that tippy... So, I pulled it out of the sea, not quite an easy task, little tools for that job, one man. Found an 2"x8" long and used that as a lever from the ropes in front of the boat. Turns out that there was a large crack in the keel in the front, well the boat went up with the front first, and high, so a lot of water/ weight was trapped inside the hull during some parts of this process. I've seen it kinda happen earlier, when the weather gets real stormy in that place, the waves manages to get across a rather large concrete quay, hammering down on the boat, then I just stood and looked, thought this was....ehhh pretty bad... went back inside.... Coffe seemed as a good idea..... Need warmer weather to fix this.... Shitty thing is; I'll probably need that crappy boat afloat in a month or two for some testing.... Don't need to go to the gym, this week..... One good thing.... ![]()
__________________ KnutS "it's dark and we're wearing sunglasses" Last edited by Knut Sand : 01-27-2009 at 06:20 AM. Reason: gunwhale - gunwale... |
#1973
| sounds like fun Knuts hope you get it fixed B |
#1974
| Well, its the fishing/ hunting boat, so a nice finish isnt needed (come to think of it a nice finish isnt needed on the other boat either...)... It still has the correct shape. It'll be a boat again, not a big problem. The temperature here in Norway, this time of the year, for a job like that, is however a tiny problem... Just have to wait, though, or some heaters. Wife always wants the boats to be out of the water in the wintertime, but its either at least one boat in the water, or a high security mental ward.... (Sooo Im on the edge now.... )
#1975
| nothing a few beer's cant fix |
#1976
| The Catlin Arctic Survey Not that I agree with what they say on global warming and arctic ice, nor that I like their commercial style show up, but I admire the guts of the "Ice Team". They will swim through the broken package of ice when necessary! http://www.catlinarcticsurvey.com/ Cheers
#1977
| I think he's starting to see daylight there knuts next thing you know old G will be sporting some new dew ( hair cut ) requires got to be glued ( worlds most serious moose ) to keep it on end and holding a Green Peace banner one can only hope cheers B |
#1978
| Washington DC weather YESTERDAY, a former chief at NASA, Dr John S. Theon, slammed the computer models used to determine future climate claiming they are not scientific in part because the modellers have “resisted making their work transparent so that it can be replicated independently by other scientists”. Today, a founder of the International Journal of Forecasting, Journal of Forecasting, International Institute of Forecasters, and International Symposium on Forecasting, and the author of Long-range Forecasting (1978, 1985), the Principles of Forecasting Handbook, and over 70 papers on forecasting, Dr J. Scott Armstrong, tabled a statement declaring that the forecasting process used by the Intergovernmental Panel on Climate Change (IPCC) lacks a scientific basis. That prince of idiots algore is scheduled to testify before the Senate Foreign Relations Committee in Washington on Wednesday morning. A "Winter storm watch" has been posted for the nation's capital, with three inches of snow forecast for Tuesday night. Legislators are now anxious to hear al-Gore's plans to combat this dangerous climate change … if they can get there through the ice and snow. http://www.wunderground.com/cgi-bin/...Select=WEATHER http://wattsupwiththat.com/ http://jennifermarohasy.com/blog/200...lobal-warming/ http://www.icecap.us/ Let us hope that this nonsense about classifying CO2 as a pollutant is rapidly consigned to the "bin of really lousy ideas" and we start building clean burning coalfired power stations, but without the carbon capture apparatus being fitted. Before anyone accuses me of talking on a subject I know nothing about, please be aware that I worked for some years in the British coal mining industry and gained City & Guilds qualifications in respect of production, distribution and utilisation of solid fuels. In other words, burning coal for steam generation. Stop press. Sales of wood burning stoves have increased by 50% in UK this winter I wonder why? Perry
__________________ Whilst entitled to your own opinion, you are not entitled to your own facts! |
#1979
| http://www.abc.net.au/news/stories/2...section=justin is a source, along with Professor RickyRood at U of Michigan who leads a course on climate change and how it interplays with business, and policy http://www.wunderground.com/blog/RickyRood/show.html , I would be inclined to trust before many other "quoted blogs"
__________________ Try to be helpful... Remember that there are at least two sides for every story... |
#1980
| ok if Guillermo can jump ship and swim on over to Green Peace island I suppose I will have to swim over to ye old Exxon Valdez and report the following from the BBC today although I am vehemently apposed to dumping iron fillings on the Galapagos's Islands Quote:
| How much will the C of G change? | Gene H | Diesel Engines | 6 | 03-02-2007 11:30 AM |
| Somebody Please help with impeller change! | SC Hartwell | Outboards | 2 | 01-14-2007 01:44 PM |
| Change My Skeg? | mcody2005 | Boat Design | 1 | 11-06-2006 12:45 AM |
| How about a change of pace? | Handtool | Fiberglass and Composite Boat Building | 11 | 09-14-2006 09:42 AM |
| Career Change | preaser | Education | 2 | 10-07-2004 11:29 AM |
