Old 10-04-2008, 01:43 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Water Maker Pressure
Does anyone knows how much pressure is required to force water through a water maker's filters ?
I have a little rolling pump that makes 100kpa or 1 bar... whichever comes first Trying to find out if it would work. It draws only 100mA under full load...
Regards
Fanie
Water ! Just gimme water !
Old 10-04-2008, 04:07 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,047
Are you building your own? Not having experience of the subject, but reckon about any presssure will work. Higher ones give more water so long the membrane doesn't tear.. Thou waiting more educated answers too
Old 10-04-2008, 04:37 PM
Fanie's Avatar
Fanie
Because the filter membranes are so fine it may be that you will need quite a bit of pressure to get the water through. I just don't know how much pressure.
Regards
Fanie
Old 10-05-2008, 12:40 AM
TeddyDiver's Avatar
Gollywobbler
Here's something I found:
http://www.rutuonline.com/html/watermaker.html
Old 10-05-2008, 12:44 AM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,505
The actual PSI I do not know but the pumps are similar to those high pressure cleaning pumps used to clean the asses of boats - somewhere near that needed to peel off blackened chewing gum or paint from a concrete footpath? it needs to be pressure regulated as significant volume is passed through the system taking the extra salt and other **** out... and a reverse flush is needed to clean the membrane every so often - go and have a look at one installed?
Try to be helpful...
Remember that there are at least two sides for every story...
Old 10-05-2008, 01:13 AM
masalai
Very interesting Teddy - Thanks very much... the first site would not load??? Wooops - - does now
Here is an Aussie site for Spectra & FCI.... http://www.outbackmarine.com.au/Mast...asp?TypeID=131
Old 10-05-2008, 02:26 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1416 Posts: 2,246
Operating pressure for DuPont membranes is 40-60 bar. Not quite as high as a pressure cleaner but coming close. Much more throughput is needed to keep the inside of the water-making tubes clean, if the flow isn't high enough the efficiency drops rapidly.
Old 10-05-2008, 08:28 AM
Fanie's Avatar
Fanie
We are not using our resources right.
How about when you go sit on your bum the chair squishes a liter of water out. When you get up the plunger and seat is pushed up again with a spring and re-filled with water. Sit down and it squishes the next...
The pressure cylinder can be in the foot of the chair.
Regards
Fanie
Old 10-05-2008, 08:50 AM
Fanie's Avatar
Fanie
Something like this.
He he... when you have enough water, don't get up or sit down
Regards
Fanie
Old 10-05-2008, 09:05 AM
Fanie's Avatar
Fanie
You can even make it so you step on it. Put glass, step and drink
Regards
Fanie
Tooler/plug maker in atlanta ga goodwrch Services & Employment 0 07-21-2008 08:31 PM
Force water out hole with air pressure Shearwater Boat Design 13 02-01-2007 10:22 AM
Tooling and Mold Maker vectorsports Services & Employment 4 11-21-2006 05:11 PM
Sea Water Cooled Ice Maker and guts for a built-in freezer? ElectricCat Electrical Systems 7 06-10-2006 09:56 AM
RIB Tube maker Jeff Therrell Fiberglass and Composite Boat Building 16 04-13-2006 05:09 PM
