Old 03-31-2004, 07:51 AM
scottscotland scottscotland is offline
Rep: 10 Posts: 10
trimaran v monohull
can someone tell me the advantages of one over the other thank from scott.
Old 09-15-2005, 09:38 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
Trimaran v. monohull
Ah weel Scottie ma wee loon - you're about to start WWIII. I'll toss the first grenade.
If you capsize a monohull with luck you'll merely end up wet and bruised. Capsize a trimaran and without doubt you're in the brown stuff without a bailer.
Old 09-15-2005, 01:48 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
Flipping in heavy seas is one consideration. I'm thinking that unless you intend on taking a great journey of many days, it's not your primary concern.
One big fat wide hull - lots of resistance due to the width to length ratio.
Two or three hulls with same buoyancy factor has more favorable ratio (narrower hulls). However will this be offset because of the increased (double and or triple) the surface area drag/resistance?
At what point does the multi-hull designs take over the mono-hull?
Water does not compress, which means that frontal area is a biggie when factoring in top speed for a non-planning hull (whether it be mono or multi).
Heavy seas
Top speed
Planning hull
Non-planning hull
Guess once you have answered some of these questions, a criteria can be developed to base additional choices on.
I'm not a Naval Architect, just a plain architect. I don't even own a boat, but I do own a hovercraft.
Are you interested in the performance envelop of a mono-hulled hydrofoil? That's another topic I'm not qualified to discuss - but that won't stop me.
Monohull verses Multihull powersailers / motorsailers brian eiland Motorsailers 257 12-14-2011 12:10 AM
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 07:54 AM
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 12:00 PM
Trimaran - Pontoon Design TSITL Boat Design 3 07-08-2004 05:42 PM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
