Old 10-03-2010, 07:26 PM
Mainteanceman Mainteanceman is offline
Rep: 10 Posts: 0
Through Hull Question
I'm replacing a porta potty with a real toilet. I've drilled a hole in my hull and installed a through hull bedded with 5200. I've received mixed signals on installing the seacock. Some say coat the through hull threads with 5200 and screw on the seacock, others say use Teflon tape. Looking for 3rd opinion.
Old 10-03-2010, 07:55 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Coat the threads with pipe joint compound. It comes in a tube or a tin.
Use the 5200 to bed the thru hull to the hull, or you can also use a polysulphide.
Old 10-03-2010, 11:50 PM
Rep: 3120 Posts: 9,384
If your hull is anything other then wood, use polyurethane (3M 5200 or similar) to bed the thru hull flange to the hull. If the hull is wood, use polysulfide. Use pipe dope on the fitting threads. Teflon works, but dope is the tried and true method. Teflon is a lot neater, especially if you have to remove it.
Old 10-04-2010, 02:08 AM
mark775
Here's a third third opinion. http://www.highsidechem.com/leaklck.html The blue one.
Old 10-05-2010, 02:10 PM
Rep: 1493 Posts: 7,447
If you put 5200 it will ooze into the threads. That is good because it will keep the backing nut from unscrewing. As PAR says, use polysulfide on a wooden hull.
Hull Fairing Question bjviking Fiberglass and Composite Boat Building 4 10-12-2009 11:12 AM
Question on Self Draining Hull jparkes Powerboats 1 05-20-2005 09:16 PM
Hull question Foiler Boat Design 4 10-19-2004 09:19 AM
Planing hull question graham Boat Design 10 12-13-2001 04:40 PM
Planing hull question graham Powerboats 1 12-09-2001 04:13 AM
