sky pool
Discussion in 'All Things Boats & Boating' started by Kailani, Aug 22, 2015.
  1. Kailani
    Likes: 8, Points: 18, Legacy Rep: 59
    Kailani Senior Member
    What kind of glass is needed to do this ?!
    http://www.slate.com/blogs/the_eye/...d_swimming_pool_at_embassy_gardens_seems.html
  2. PAR
    PAR Yacht Designer/Builder
    There's only one kind of glass you can do this with and damn it'll be expensive stuff at that thickness. Seems a silly thing for the aesthetic and contrivance of this project.
  3. Rurudyne
    Rurudyne Senior Member
    Maybe Scotty divulged the secret for transparent aluminum after all?
  4. philSweet
    Likes: 461, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
    random thoughts.
    1. It WILL look awesome lit up at night.
    2. Needs maybe 1 million BTU per hour of heat in the winter...
    3. ... which will cause a lot of evaporation which will condense minerals onto the outside of the pool. Said minerals are about as hard as the glass. Going to need some trick coatings to prevent etching and scratching.
    4. How many days per year can you comfortably lounge on a tenth floor sun deck in a wet swimsuit in London?
    5. How many Plecos to control the algae?
    6. It would sorta suck if you left the hose on and overfilled it.
    7. And no, you can't drain it in the winter. It will serve as both buildings' central sprinkler system reserve. But maybe ice skate on the top?
    8. And will they have ducks like the Peabody in Memphis?
    https://www.youtube.com/watch?v=wwo9L8L_i3U
  5. Mr Efficiency
    Mr Efficiency Senior Member
    Dud idea, a vandal with a glass cutter will fix it !
  6. jehardiman
    Likes: 1,171, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    I'll bet it's not glass but Acrylic, possibly with a PVHO rating. Similar to the circa 1996 Monterey Bay Aquarium Outer Bay viewing window.
    From the paper www.intaquaforum.org/PROC MONACO II/045-Davis.doc
  7. SukiSolo
    Likes: 27, Points: 0, Legacy Rep: 271
    SukiSolo Senior Member
    Mmmm and I thought this was a new James Bond movie......;)
  8. Rurudyne
    "You Only Swim Twice"?
  9. PAR
    Brilliant . . .
  10. Rurudyne
    Just an aside: in a super posh pool like this, so very visible to so many people, they can't use those chemicals that change color when someone pees. Can you imagine the furor from that kind of paparazzi picture?
  11. SukiSolo
    Or maybe a View to a Spill?
  12. Rurudyne
    :D
    Or "Octagenaria- ..."
    No, so not going there.
  13. SukiSolo
    Poolraker?
  14. philSweet
    Captain Obvious is going with Skyfall
  15. PAR
    Water temperature could be checked by nipple erectness . . .
