| Short Shaft Outboard on a Long transom Hello, I recently inherited a 40 hp short shaft Tohatsu and would like to put it on my 16' Sundance skiff; very similar to a Carolina skiff. Could I make the motor work with a jackplate? I have a dealer that is certain it will work, but I would like to get other opinions before diving in to this project. Thank you for any suggestions. David |
| If you get the prop down far enough then yes it will work. BUT it is possible, depending on your boat that you will get the engine swamped when the stern wave catches up with the boat when you slow down. Some engines can be converted with a leg extension gear drive shaft water pick up and gear rod. |
| Thank you for your response. |
| 280 short and long shaft units | acsnowrider | Sterndrives | 1 | 04-11-2007 08:39 AM |
| is it a short shaft or long shaft? | donell67 | Outboards | 2 | 03-13-2007 11:07 PM |
| long shaft or short shaft | Bill Kubiak | Powerboats | 17 | 05-26-2006 12:00 PM |
| long shaft transom height? | Baldur | Boat Design | 5 | 07-10-2005 11:28 PM |
| short shaft motor on long shaft boat | ohenry | Boat Design | 0 | 03-21-2005 08:02 PM |
