Old 05-17-2008, 04:38 AM
Spin_Drift's Avatar
Spin_Drift Spin_Drift is offline
Sea Witch
Rep: 10 Posts: 11
Shipping a boat from overseas... (Shipping a wooden boat from Finland to Alaska)
Sorry if I posted this in a wrong forum. I'm new here.
Does anyone have ides on what is the best way to ship a 25-26 feet long 7.5 feet wide cabin cruiser from Finland to Alaska?
I have contacted and prodded Victor Ek, a local company here in Finland and waited for answers since March. It seems they can't or are unwilling to help us.
Can you recommend any reliable international shipping companies?
Would be best to build a crate around the boat and block her and try to ship her that way?
Or, -should we buy a boat trailer for it and ship her that way?
Thanks for any help you can give us.
Please, tell me where this post belongs and I'll be glad to move it, if it should be moved.
Choose wisely -Treat kindly...
You can put your children and family first and still follow your dreams! I'm a living proof...
When the storm breaks, each man acts in accordance with his own nature. Some are numb with terror, some flee, some hide, and some spread their wings like eagles and soar on the wind...
Old 05-17-2008, 04:41 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,539
To my mind
only one way = container (not cheap)
too much work has already gone into this boat
she is beautifull
Old 05-17-2008, 04:46 AM
Spin_Drift's Avatar
Sea Witch
Rep: 10 Posts: 11
Originally Posted by Manie B View Post
To my mind
she is beautifull
Thank you.
I've looked at containers, but they are narrower than the boat.
Do you or someone else know where can a wider container be gotten, if they are available?
Does anyone have an idea how much shipping her might cost? Ball park figure!
Victor Ek has not given us any info and we are getting ready to move back to Alaska this summer.
Old 05-17-2008, 05:12 AM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Most containers (you'd need a 40 footer) have internal dimensions of 7 feet 7 inches so theoretically with a lot of care you'd be able to ge your boat inside! Save on the packing a bit as well!!
Failing that your best bet is to build a crate around the boat! Send her deck cargo, with that beam and the size of the crate you wouldn't be too far outside that of a container but still outside! So a lot of companies wouldn't be interested - they can only "think inside the box" (no pun intended), if you can't get a local one how about somebody from further afield? Which ever you choose unfortunately it rathe looks like it may be expensive!
Don't forget when you do ship it make sure the boat is properly packed and covered - especially if going deck cargo! Whilst every care is taken once at sea it has to fend for itself, weather conditions may be pretty bad - salt spray and waves can do a hell of a lot of damage on their own!!
Old 05-17-2008, 06:20 AM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
One beautiful bit of work, insure her and look after her well.... (The boat - I'm married but I would marry the boat - that is still legal)
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 05-17-2008, 07:35 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Some container shippers claim inside widths of 7'8" but I find that 7'4" is a safe number to rely on. Your boat is 7'6" wide so it probably won't fit upright ... but how TALL is it? You can probably ship it on its side in a high-cube container if its height is less than 7'4".
You might not have to tip it completely sideways either. Some boats with cabins narrower than the max. beam (such as yours) can fit in a container just by tilting them a little bit., maybe 10-15 degrees.
A container will probably cost you $5000 for shipping, maybe more with the rising cost of fuel these days. Deck cargo will cost you at least twice as much as container shipping (maybe 3x as much) so check the dimensions carefully and see if you can get it inside a container before you consider deck cargo.
Kenneth Grome
Old 05-17-2008, 11:32 AM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1298 Posts: 1,991
I'm not sure if it would help, but you could get it from here to Vladivostok with train. From there don't know sure but maybe with some russian costal frighter up the coast to Kolyma region? and short cruise to Alaska..
Old 05-18-2008, 06:57 PM
murdomack murdomack is offline
New Member
Rep: 262 Posts: 264
Try a palletwide container, these will fit in a ships container cell (8ft), and are the same footprint as a normal ISO container. Here are some dimensions.
GESeaCo 40' Palletwide Container 9ft6 "SeaCell"
Internal Measurements
Length 12.03 m
Width 2.35 m
Door Width 2.34 m
Height 2.69 m
Height at doors 2.58 m
Container weight: 3800 kg
http://www.geseaco.com/GESeaCo/Conta...yFreightBoxes/
You can also get an inland container that is 8'-6" wide but it would not fit a cellular containership and would cost a premium to ship deep sea.
Your other option if your 7.5 ft is accurate is to get an open top container or an ended flatrack. If the shipper could box the flatrack between other containers it would help to shelter your boat from the elements, or it could go in the hold cells.
There is also an open sided container with sheets, that would be like the flatrack with a roof. I'm not certain if these are accepted deep sea or not.
I would get an accurate beam measurement done and my choices would be a palletwide followed by an open-top if you can get the boat into either. If you are beaten by a couple of inches, then the flatrack might keep you within the cell guide measurements and save you a lot of extra money.
I hope that you haven't underestimated the beam as you will be charged for at least an extra cell if your beam is over 8 ft
Old 05-21-2008, 03:13 AM
Spin_Drift's Avatar
Sea Witch
Rep: 10 Posts: 11
I'd like to thank you all for getting back to me.
I'm getting someone her to help me get the exact measurements of the boat, this weekend.
Will get back when I know more. Thanks again...
Old 05-23-2008, 07:45 PM
RHP's Avatar
RHP RHP is offline
Rep: 1073 Posts: 568
I would go with the tilt suggestion in a normal 40' container simply because of the protection afforded by the container structure. You might have to make a tilt trailer/frame first, place the boat and then wheel the frame into the container rather than try and tilt whilst loading.
Good luck and definitely keep us informed!
Richard
Old 05-24-2008, 01:29 AM
Spin_Drift's Avatar
Sea Witch
Rep: 10 Posts: 11
Has anyone ever transported a wooden boat in a tilted position? This one weighs a lot and I'm afraid that beind in a tilted position for a couple of months might do her some structual damage.
I can see that would be OK with a fiberglass or alumin boat...
Old 05-24-2008, 01:47 AM
TeddyDiver's Avatar
Gollywobbler
Originally Posted by Spin_Drift View Post
Has anyone ever transported a wooden boat in a tilted position? .
Obviously it fit's in when tilted You need maybe a 150m 2''x4'' timber, chainsaw, spike gun, old car tires, cargo jacks and a couple of days to do the trick. You can give me a call if need a hand
Old 05-24-2008, 05:26 AM
safewalrus's Avatar
Ancient Marriner
I'd still have my doubts - the keel is the stongest memeber for various reasons - a boat ain't designed to lie on it's side for any length of time! If it was it would be built different!!
Old 05-25-2008, 11:09 AM
New Member
Rep: 262 Posts: 264
Have you measured the beam accurately yet? Do you really need to tilt her? You can get storm videos on Youtube of the weather that containerships cope with. They may be big but they still get bounced around.
Old 05-25-2008, 06:03 PM
Spin_Drift's Avatar
Sea Witch
Rep: 10 Posts: 11
Should get someone to come here and measure her tomorrow.
I am worried about tilting her for the long journey.
Will keep you posted when I have the exact measurements.
Thank you, SpinDrift
Can you post a link to the above videos?
Shipping costs Maybeoneday Marketplace 2 03-28-2008 12:56 AM
A new Shipping Website. shipdays.com Press Releases 2 08-08-2006 04:12 AM
SHipping overseas pinsk22 Open Discussion: All Things Boats & Boating 0 02-11-2006 02:02 PM
Shipping a mold Thomas Krane Boat Molds 3 01-01-2005 11:41 AM
