Old 03-13-2004, 06:18 PM
Becky
school
Hi i'm in the eighth grade and for a science project i have to build a small boat (no more than 25X30cm). It has to be able to hold atleast 500 gm. I was planning on making it out of wood but i have no idea what to do! any suggestions?
Old 03-13-2004, 08:36 PM
betelgeuserdude betelgeuserdude is offline
Registered
Rep: 10 Posts: 62
Hi Becky.
Was it you who also posted in the "should guests be required to register" thread?
DC
Old 03-13-2004, 09:57 PM
Becky
yes, why do you ask?
Old 03-13-2004, 10:48 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Hi Becky,
Please tell us what type of school you are attending that requires you to design a boat while in the 8th grade. Is this for a math class? What other tools are you given to solve this problem?
Don’t worry about registering, like you said it takes a long time and we want get right to doing your assignment for you.
Gary
"The hand feeds the mind."
Weston Farmer
Old 03-14-2004, 12:46 PM
mmd's Avatar
mmd mmd is offline
Rep: 306 Posts: 378
I would make it out of what we around here call Bristol board or poster board, fastened with masking tape. The boat must be a hard-chine (speedboat) boat type. When building is complete, two coats of ordinary housepaint will seal all holes and add suprising rigidity.
I often use this method to do a quick mock-up of a hull for discussions with clients. Attached is one I did of a 6 metre (18 foot) sailboat.
If you'd like, I can e-mail you the layouts for panels of a simple boat for this construction method. Let your mom or dad know that you are going to talk to me on-line first, though. They may want to check out my profile or talk to me first. I'd expect my 13-year old daughter to tell me, so I'll expect the same from you, OK?
Michael
Old 03-15-2004, 10:56 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
If the aim is simply to hold as much weight as possible for a given size, you might want to consider a simple 'punt' shape (basically a box with one end - the bow - turned up). It would be easiest to make, would carry the weight well and be most stable for its size....
but like the others have said - give us a little more info and we can probably help more...
Will
Imaginocean Yacht Design
www.imaginocean.net
The Landing School bobothehobo Education 7 02-02-2005 03:01 PM
The Landing School Student Introduction / journal thread samh Education 14 05-29-2004 06:36 AM
What Graduate School to go to? Brad Carlson Education 2 04-18-2004 03:28 PM
the comment for the school. kung0215 Education 3 12-07-2003 04:27 PM
Westlawn: NMMA Transfers Yacht Design School to ABYC Guest Education 0 09-04-2003 09:25 AM
