  #31
Old 04-23-2007, 05:48 PM
SamSam SamSam is offline
Rep: 497 Posts: 1,680
Originally Posted by marshmat View Post
Egad. Sounds kind of like a half-assed quick fix to hide the problem. Any proof that it actually holds together in the long term?
RCardozo said it's been on his boat since the '70's. They've been doing boats like that for 20 years or so around here and are still doing it. Sam
  #32
Old 11-24-2007, 07:00 PM
RCardozo RCardozo is offline
RCardozo
Rep: 21 Posts: 51
This is what I did
For those of you who helped out this is what I ended up doing:
First of all the material is wrought iron not cast iron. I can be welded using 6011 rod. I beleive itb is about 25 ksi in strength.
The boat was hauled on a railway. I inspected the bottom and cut away the areas that looked to be leaking. Once the fiberglass was cut off The iron was exposed. Some areas had severe corrosion and some not. The fiberglass was bonded to the hull. There was no 5200 sealant. What would happen was that if water entered a crack in the glass then the iron would corrode. That would loosen the bond between the fiberglass and the iron allowing water to advance sideways. In areas without corrosion the glass was bonded to the iron such that to remove it you needed a crowbar. In the areas with a good bond the iron was in excellent shape. I ended up removing about a 15 x 15 area of concretre, glass and steel and replacing the steel frames, plate and the reglassing the hull with about 3/8" of fiberglass alternating matt and roving. I also went all over the bottom and ground out and touched up any fiberglass areas that looked to be cracking or weeping. The boat is launched and no leakes. The culprit was an earlier patch that had a bad cold joint in the glass. Once the water got in it did its thing. Oddly enough the condition of the steel was pretty good and the majority of the hull was sounded and the fiberglass was not delaminating. I will continue to monitor the glass like a hawk and fix any imperfections. Hopefully without the water the hull will be stable for awhile. The concrete was a pain to remove. I am not sure how bad the concrete and steel were toegther but when you add water you have a real issue. Still about 1/3 of the hull has that condition. The hull is watertight in these areas so I hope I have no ongoing corrosion under the concrete. Anyway it was expensive but i think I did a good repair and only time will tell.
Thanks for the help.
  #33
Old 11-25-2007, 12:11 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,756
Glad to hear you got the problem sorted! Here's hoping that's it!
Mike (the 'walrus)
  #34
Old 11-25-2007, 08:49 PM
charmc charmc is offline
Rep: 840 Posts: 2,391
RC,
Thanks for sharing the results. It sounds like a careful, conservative approach. Hopefully you got all the corrosion and cannow focus on enjoying that uniquely beautiful boat.
Good luck!
Best,
Charlie
Cast Iron Swing Keel Repair...Need Tips! Guest Sailboats 12 09-26-2010 10:21 PM
Need advice on seam sealant for riveted aluminum sailboat Thaddeus Metal Boat Building 10 05-28-2006 09:09 AM
How to remove paint from the hull of a riveted aluminum boat? whalepass Metal Boat Building 3 04-24-2006 09:23 AM
Hull Repair devindamarko Sailboats 13 01-23-2006 03:18 PM
hull repair eurotk1 Fiberglass and Composite Boat Building 13 04-17-2005 10:53 PM
