Old 05-05-2011, 03:30 AM
cattelona cattelona is offline
Rep: 10 Posts: 15
raw water intake pipe
hi ,
just about to finish work on my coronet 21 dc with volvo 200 legs, replaced one of the two deisel engines tuns of rubber bits , O rings ,oil seals , impellers etc etc etc, existing raw water intake pipe is reinforced hard plastic like stuff I have had trouble with it staying on the connections , i understand that as its drawing water in its under negative pressure it may collapse but is there a rubber hose that would do same job , or is any good quality rubber hose ok even when it gets hot ? also what is the best type of fuel filter for a marine deisel , i cleaned out tank last year and will check it again this year but i seem to have to change filters quite often , how many microns etc i have fitted a water separater type filter , a friend has similar trouble ie fuel starvation at high revs he has two in line is that too many filters his boat is only two years old , it has fly by wire throttle with lots of pcb s its a vw deisel and just dropes back to 2k revs and stays there .
thanks
nick
Old 05-05-2011, 03:37 AM
Dean Smith Dean Smith is offline
Previous Member
Rep: 0 Posts: 0
g,day Nick
The best type of Primary filter you can use is Racor, with sight bowl under.
just you and your friend make sure you lines are big enough, supply and return
10mm both on the 200 shp
Old 05-05-2011, 04:28 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,834
I heard once that fuel at the petrol station was filtered to 25microns 5 microns to the engine is real nice but you will be cleaning a lot, depends on the quality of fuel you buy.
I use PVC pipe on my intakes, they don't collapse, cheap and ubiquitous 1.1/2 if I remember. You can build in a extra nipple to the hose pipe for fresh water flushing.
Old 05-05-2011, 11:21 AM
Rep: 10 Posts: 15
hi frosty,
many thanks for your remarks.
nick
Building Raw water filter with PVC pipe mydauphin Diesel Engines 9 11-24-2010 04:44 AM
90 deg elbows in raw water intake pasty63 Diesel Engines 17 09-08-2010 11:19 AM
Raw water intake strainer size seven up Inboards 4 11-06-2009 07:18 AM
are raw water strainers a must? alibi Inboards 9 03-09-2009 08:47 AM
intake manifold water neck new2boatingguy Sterndrives 1 10-15-2008 11:05 AM
