  #166
Old 06-10-2006, 11:41 AM
Vega's Avatar
Vega Vega is offline
Rep: 127 Posts: 1,606
Originally Posted by Wellydeckhand
Ok I owe some brief explaination.
The dayak are well acustom to forest missionary, especially boiled one...... but then it was the beginning of christianity coming to Borneo, you really need patriot evangalist.
WDH
Welly, I don’t understand, I thought that they were Christians and that was part of the problem. Is this correct?:
"Violence between Dayak and Madurese has occurred several times in in West Kalimantan -- eight times in the last two decades. Ethnic tensions continue in West Kalimantan, where hundreds of people were killed and thousands displaced following fighting that began in late December 1996. …
Bloody clashes between the indigenous Dayak people, migrants from Madura and the military started in early January 1997, and resulted in a death toll of over 500; the army admitted to 300 dead. The army sent in 3,000 troops to fight tribesmen, including six battalions of troops and the Army Strategic Reserve…
Tensions between Dayaks, who make up 40 per cent of West Kalimantan's population and have converted to Christianity, and the Muslim Madurans have been fueled by fears that the migrants will take away land and jobs from the indigenous people. Dayak communities have been dispossessed as their traditional forest lands are appropriated by outsiders in government-supported resettlement, development and large-scale commercial enterprise schemes."
http://www.fas.org/irp/world/para/dayak.htm
The Madurese first arrived in West Kalimantan in the 1930's, but the numbers increased during the 1970's. This was the result of the Indonesian government's transmigration plan, which encouraged people to leave more populated islands such as Madura and Java for low populated islands such as Kalimantan. Little consideration was given to the indigenous Dayaks. As the rainforest was cut down and replaced by palm oil and coconut plantations, the indigenous tribes found themselves at the bottom of a complex hierarchy of different groups, unable to continue their traditional patterns of agriculture and slow to adapt new types of employment. (Economist, 1997) The Christian Dayaks now share the low end of the economic ladder with the Madurese. There are currently about 100,000 Madurese in various parts of Kalimantan and two million Dayaks from at least ten separate tribes.
http://www.american.edu/projects/man...ce/kaliman.htm
  #167
Old 06-11-2006, 03:10 AM
Wellydeckhand's Avatar
Wellydeckhand Wellydeckhand is offline
Previous Member
Rep: 36 Posts: 1,403
Dayak are kind people
The land of Borneo belong to The Dayak tribe or race that think dayak......... Race like Kenyah, Bahau, Benua, Tidung, Kayan, Modang, Punan, Iban and others' I have no info on........... the Mayan and the serious type muslim in the central kalimantan are different.
These dayak regardless of religion will band together to wipe out any enemies that they think is a danger....... a meeting of Kenyah Lepoq Tao King gathered everybody in ancient days and made everyother king to swear under oaths and that still hold true until now. The will feast again only during war of extreme situation and condition.
Not all dayak are Christian....... quite a big part also take up muslim believe and some still like to worship nature........
Now the madura had it comming as they grew in size and seized land own by the dayak without permission and played out politic agaisnt the native. The Dayak of course use the wait and see attitue until they think it is time to do something about it.
Now the last warning of Madura and Dayak happened a few month ago with a ritual between 2 races with an oath to finished the business if the Dayak is offended again....... but this time would be the final...... so Madura i think is tip toe very softly in this region and would settle or disown any madura that created the problem.
The Headhunter are fair people until a form of disgrace is openly felt by them. They are well oiled mandau(Blade) waiting for an open practice.
I do not find any problem with them as I try to repay their kindness by calling in professional investor to open up plantation where they will benefit through plasma system.
They have trust and believe Indonesia care and taken in Pancasila as a motto to live with, to regard all the same with different background and believe..... (Kalimantan Dayak)
I have 4 headhunter chieftan on the table for my deal, as a broker, I was asked for help not the other way around........ I could have settle for south Kalimantan but still think East Kalimantan is better.
WDH
  #168
Old 06-12-2006, 06:27 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Does anyone know what the reason is for this rudder? How does it work? Sam
  #169
Old 06-12-2006, 06:52 PM
SeaSpark SeaSpark is offline
Rep: 96 Posts: 593
pendulum rudder with a movable prop
Interesting post!
Looks like an combination of a pendulum rudder with a movable prop shaft.
The engineering does not look very well executed, the "hinges" between the main and pendulum seem very close to each other. The bottom hinge could be much more near the prop. Even below the prop there is room for an additional hinge. This would make the whole thing much more strong and protect the prop.
The whole contruction seems way to complex to compensate for any possible benefits.
The picture was to taken in a museum, if you know where it is more information should be easy to get.
(edit)
Found source, in french
http://babel.lexilogos.com/fluvial/a...0berrichon.htm
babelfish translation of part of text:
The constraints of gauge of the channel of Berry, to which those of a maximum load capacity are opposed, lead sometimes the motorized berrichon to be equipped with a system with control surface and complex propulsion: the motor bike-scull "assemble-and-drops", which makes it possible to completely fold up the saffron in the small locks.
Apparently this system enables the rudder to be folded so the boat can be made longer and still fit in the small locks in the french canals.
  #170
Old 06-13-2006, 12:27 AM
Previous Member
Gang Band
Here an album from Italiano........... anyone heard of it?
  #171
Old 06-13-2006, 07:25 PM
That makes sense and it does seem to be pretty complicated for what it accomplishes. I had seen the English translation elsewhere and got hung up on the 'scull' part and was trying to imagine the whole thing flapping back and forth, sculling somehow. With the movable propshaft, it seems like an outboard with a rudder attached to it. I wonder how that would work..? Sam
  #172
Old 06-13-2006, 07:48 PM
5 outboards
I saw a photo of a boat with 5 outboards on it somewhere, can anyone tell me where the photo was? Sam
  #173
Old 06-13-2006, 09:40 PM
Previous Member
SamSam,
Maybe this one? see anything you like?
Random Picture Thread-37857.jpg  Random Picture Thread-10071horsepower.jpg  Random Picture Thread-10071lotsamotors.jpg
  #174
Old 06-14-2006, 03:36 AM
Rep: 96 Posts: 593
Multiple outboards
Our member Ranchi Otto likes to design boats with many outboards, http://www.boatdesign.net/forums/profile/ranchi-otto.html
  #175
Old 06-14-2006, 05:00 AM
Previous Member
Yup, Ranchi Otto is a Great designer..... only he did couldnt put multi outbaord on this boat.......... what a pity .......................
WDH
  #176
Old 06-14-2006, 05:18 AM
hansp77 hansp77 is offline
Rep: 200 Posts: 691
Welly, I may have just found the plans for my $100 boat…
  #177
Old 06-14-2006, 05:33 AM
Previous Member
hansp77 try a free sampan plan in forum....... sampan mean 3 plank boat, you will be surprise it is a good boat to build with that budget.
  #178
Old 06-14-2006, 07:31 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
No one want to see this, but a lesson learned by one marina owner - I guess.
http://forums.pelicanparts.com/showt...03#post2644903
  #179
Old 06-14-2006, 05:18 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Whoops
guess the moral is don't leave the galley stove on when you go for a wee!
Seriously sad for the owner(s) tho'
  #180
Old 06-14-2006, 06:31 PM
SeaSpark, This is the one I saw. I was wrong, I guess it would be underpowered with only 5 engines.
Welly, Is the one with 8 engines a real picture? Do you know what the ones with 5 are used for? They look well used.
Thanks guys, Sam
Skiff Design Thread TimClark Boat Design 36 02-20-2006 06:03 PM
Need your help I'm Looking for a picture… rotorhead Boat Design 2 12-16-2004 11:44 PM
Geek question - can't see thread titles - HELP!!!! SailDesign Open Discussion: All Things Boats & Boating 13 11-24-2003 10:03 AM
New Forum Thread 1 duluthboats Option One 6 05-17-2002 03:24 AM
