Old 11-22-2009, 07:28 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1416 Posts: 2,244
Originally Posted by owene View Post
Yes, although if I'm going to the effort of machining one up, I may as well do three (one spare)..... Good food for thought.
No, just the one at the rear. You press the two halves in the groove, slide the cupped washer over them and install the bearings. Doing the same at the front is possible only when the cupped washer comes last and all axial play is eliminated or at least reduced to a gap small enough so the collars cannot slide out once the bearings have run in.
And if you ever need the 3rd set, you have been in big trouble!
Old 11-28-2009, 05:21 PM
Rep: 1493 Posts: 7,447
All motors are on rubber mounts. How is this sophisticated or different? You just put a coupler, get rid of any spline unless it is locked, and bolt them together.
Old 11-28-2009, 06:06 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Gonzo- For whatever reason, Owen's drivetrain has universal joints in it. Possibly because the geometry wasn't favourable for having just a straight shaft to the engine, or perhaps it's so that the engine can be on soft vibration-damping mounts (the reason that Dashew yachts and many other high-end craft use CV joints). Since the universal joints won't transmit axial loads directly to the transmission, an additional thrust bearing is needed.
Old 11-28-2009, 06:45 PM
owene owene is offline
Mr Owen Charles
Rep: 10 Posts: 12
Gonzo, I guess that you haven't read my first posting. Not all motors are on rubber mounts but mine is. If I put it on fixed mounts with a direct coupling to the shaft, the motor would be tilted up at 18 degrees to match the shaft - somehow I doubt the Cummins warranty would be worth more than a roll of dunny paper. Also, if I do away with the rubber mounts, the boat will sound like a drumming machine with all of those engine noises. Marshmat's comment above is exactly correct.
Old 11-29-2009, 06:30 AM
I haven´t seen an engine that is not on rubber mounts in years. Old wooden boats had hard mounts, but the hulls are flexible and absorb vibration. 18 degrees is a lot. They make drop angle transmissions for that application. It would be much cheaper than engineering a thrust bearing and mounts for it. U joints should be able to take the thrust if they are sized properly. The small length difference will be taken by the shaft sliding on the cutlass bearing like on every other installation.
Old 11-29-2009, 12:05 PM
CDK's Avatar
CDK CDK is offline
retired engineer
No Gonzo, you're wrong. Rubber engine mounts that have to cope with axial loads are made to offer some transverse movement, but in the axial direction they are stone hard (width/length 1:4 or more) and transmit a lot of vibration.
A far superior way is to use soft mounts, double universal joints and a thrust bearing.
And of course the angled joints cannot take any axial force, no matter how large they are. That is a basic engineering rule.
Old 11-29-2009, 12:15 PM
I know I am not wrong. The mounts are a bolt surrounded by rubber.
Old 11-29-2009, 12:37 PM
CDK's Avatar
CDK CDK is offline
retired engineer
As always, there are cheap ones and good ones.
The one in your picture is stone hard in any direction because the rubber has nowhere to go.
Old 11-29-2009, 01:18 PM
Come on CDK I show you were wrong and now you're being petty. The upper one you show is a Yanmar type. They move in all directions until the metal stops it. The lower one is the same. The photos I posted are the factory mounts for Mercruiser and VolvoPenta. They are not rock solid, that is BS. The rubber allows some movement. If you want to discuss a point do it with the truth.
  #25
Old 11-30-2009, 06:54 AM
Rep: 501 Posts: 1,760
I am on your same mission, lets talk, I have other parts of system, email me at mydauphin@gmail.com Perhaps we can build 6 and save some money.
  #26
Old 11-30-2009, 07:54 AM
CDK's Avatar
CDK CDK is offline
retired engineer
The pictures I posted came from Marine24.com and are no standard issue for any engine, although the diesel engines I have seen installed in sailing boats and cruisers (also Volvo) without exception were this type. They are available in 50 and 60 shore and allow a lot of movement sideways, but axially it is limited to a few mm's only. The geometry is approx. 1:4.
The one from your picture I've seen under large industrial electric motors, under small diesel generators and a few times in fishing boats. I've had 5 Mercruisers and one OMC, none equipped with such feet.
The diesel engines in my boat stand on cylindrical feet of a different design. They cannot take any axial force at all, but they don't have to because the thrust bearings are incorporated in the oil filled stern tubes.
  #27
Old 12-01-2009, 12:40 PM
A few milimiters of fore an aft play is not rock solid. The mount I posted is from the Mercruiser catalog.
bearings for freestanding rotating mast Timothy Sailboats 2 08-11-2009 02:52 PM
shaft bearings ideas please Guest62110524 Metal Boat Building 41 07-13-2009 03:01 PM
Canting keel bearings - Bulkhead attachm. lausl Fiberglass and Composite Boat Building 2 12-30-2008 09:23 AM
Shaft Length Between Bearings bridgey Boat Design 4 01-15-2008 06:49 AM
radial pitch distribution of Ka series shoaib_jaff Propulsion 1 10-02-2006 02:46 PM
