  #226
Old 11-30-2011, 01:14 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Originally Posted by Dave Gudeman View Post
Can someone explain why all of these calculations are assuming that the faster-than-light neutrinos in the experiment and the faster-than-light in the supernova would be going at the same speed? Is there some reason to assume that neutrinos have a constant speed?
I base my YES ( assuming you are happy with the velocity in the range of ~ C as close enough ) on -
http://en.wikipedia.org/wiki/Neutrino
If you need a higher precision than that - then that is indeed unknown.
Basically, a neutrino is a neutrino whether it was generated from an accelerator or a supernova.
"There are three known types (flavors) of neutrinos: electron neutrino ν
e, muon neutrino ν μ and tau neutrino ν τ"
"Before 2011, experimental evidence could be interpreted to mean that neutrinos traveled at or below the speed of light. Following the results of the September 2011 observation of faster-than-light neutrino velocities in the OPERA experiment, the value of the neutrino velocity is the subject of theoretical and experimental studies.[29]
Theory
Before the idea of neutrino oscillations came up, it was generally assumed that neutrinos travel below or at the speed of light."
" 2007 using the MINOS detectors, which found the speed of 3 GeV neutrinos to be 1.000051(29) c at 68% confidence level, and at 99% confidence level a range between 0.999976 c to 1.000126 c."
  #227
Old 02-24-2012, 12:14 AM
Mr Efficiency Mr Efficiency is online now
Rep: 246 Posts: 711
http://news.yahoo.com/faulty-wire-er...233455932.html
  #228
Old 02-24-2012, 01:04 AM
rwatson's Avatar
"This is a complicated experiment with a multitude of cables and equipment," said Marsollier.
"The physicists have checked things out, are continuing to make checks and will check again. It (a technical flaw) is always possible, but they have been saying this from the very beginning."
Hey Mr Arbitrator - I think this thread shoudl be moved from Boat Design - whaadya reckon ?
Last edited by Boat Design Net Moderator : 02-24-2012 at 01:24 AM. Reason: < thread moved as requested >
  #229
Old 02-25-2012, 07:03 PM
rwatson's Avatar
You certainly cant complain about the service on this site - thank you Mr Moderator :-)
  #230
Old 03-06-2012, 01:01 AM
tom kane's Avatar
tom kane tom kane is offline
Rep: 287 Posts: 887
The Universe does not make any sense unless we (humans) can eventually travel through space at speeds much faster than the speed of light. I can easily travel to several planets in a few seconds. In my imagination,nothing much faster than that.
tomkane
  #231
Old 03-06-2012, 01:09 AM
rwatson's Avatar
The latest report has several possible errors in the process. One is a an over oscillating crystal in one clock, and a faulty optical cable to the receiver.
sticking down carbon cloth! drtcmm Materials 19 11-29-2010 04:49 PM
mercruiser starter motor sticking mogmcfc Powerboats 15 11-17-2009 03:08 PM
sticking up pole on FL trailers yipster Powerboats 8 04-15-2004 07:11 AM
