| Question From A Newbie Is a canoe a displacement hull or planing? If it can be planed how big a motor would it take for a sqare stern 12' canoe 14" deep 42" beam Thanks alot |
| Hi muddin, Canoes, almost by definition, have pure displacement hull shapes intended for extremely efficient low speed operation. They serve this function very well. Most attempts to power or tow canoes to higher speeds tend to result in the canoe either becoming uncontrollable, or breaking up. (Notably, they cannot be towed behind powerboats at planing speeds; quite a few have been destroyed this way). Powering a canoe with a bigger engine than is necessary to get it to a bit past hull speed is not a good idea, and could very well result in the loss of the boat.
| Canoes can be flat bottomed and plane, shallow arched bottom for best secondary stability (these are best for rougher water), or round for best speed under paddle. The transome stern doesn't enter into it unless the boat is loaded stern-heavy or designed to be a boat other than a canoe unless the stern draws down and brings the transome into play. Canoes have a "canoe stern", at least under the water, and any that I know wouldn't plane well. I presume you want to get somewhere fast, then paddle around. It is a pleasure to glide well and anything that planes well will not glide well. This is practical experience, as I know it. Perhaps a designer can enlighten us more. |
| Sorry, Matt had it covered |
| muddin, I just re-read your dimensions: 3'6" beam on a 12' LOA vessel is awfully wide for a canoe. Are you sure that's what you have, and that you aren't talking about a small skiff of some kind?
| this is my canoe Fisher 12' (Square Stern) Perfect for sporting activities and recreational use, the Fisher is incredibly stable and can be rowed(2 position) or propelled by a small motor (up to 2 hp)! Fabricated in fibreglass, with heavy duty aluminum gunwales and hardware, along with wood slat seats. In addition, each with sports external sponsons to provide "stand-up" stability. Yet our Fisher is still small enough to tie down on any car or in the back of a pick-up. A very versatile little boat; small but mighty! Length 12' Beam 42" Depth 14" Weight 65 lbs. Capacity 420 lbs. http://www.langfordcanoe.com/files/C...1169813807.jpg Last edited by muddin redneck : 08-13-2009 at 09:22 PM. Reason: additional pic |
| muddin redneck are you that heavy (Capacity 420 lbs.) or do you like to carry a lot of stuff?
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
| well im not a small guy im 6'2" 300# so after some gear and a small outboard the capacity weight is all but used up and my dog ALWAYS has to go with me to and he's 40#'s |
| Buy an exercise bike of row boat and get fit whilst loosing some of those excesses, then you can better enjoy the rest of your life and be around longer to do it ![]() ![]() You need to loose about a third of your weight at least...
| dont need a diet plan just some boat info |
| The non-boat info, consider a bonus, and just as important...
| Newbie with glass ID question | Jbird | Materials | 1 | 08-21-2007 10:55 PM |
| Newbie here with newbie question. Marine plywood or plywood? | photojunky | Wooden Boat Building and Restoration | 30 | 07-23-2007 06:41 AM |
| Newbie here has a question about a Dingy | Chuck R | Wooden Boat Building and Restoration | 6 | 05-07-2007 10:32 PM |
| Newbie Question | Scottlaf | Fiberglass and Composite Boat Building | 2 | 11-10-2006 06:37 PM |
| newbie with a question | wolter9 | Fiberglass and Composite Boat Building | 6 | 07-01-2006 06:41 PM |
