Old 06-28-2009, 03:36 PM
planeman planeman is offline
Rep: 10 Posts: 0
a question about gluing
Kindly forgive what must be a rather simple question, but why
are wooden masts glued rather than fastened. I've consulted
Chapelle and he does not really treat this subject other than
explaining the gluing process.
Old 06-28-2009, 04:45 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Becouse it's much better in many ways.. stronger.. lighter.. long lasting etc
Old 06-28-2009, 05:16 PM
wet feet wet feet is offline
Rep: 99 Posts: 258
If you look at the publication dates of Chappelle's books they pre-date the availability of reliable waterproof glues.In spite of this,glue was used.The more relevant consideration for masts is that a glue bond is uniformly strong.A line of fasteners is strong at the points where the fasteners are located and will become weaker after numerous cyclic loads are applied.It is also quite difficult to shape the mast if there are fasteners present.If you are building a replica large ship from the mid nineteenth century or earlier different considerations apply.
Old 06-29-2009, 12:00 AM
Rep: 2891 Posts: 8,798
With the exception of through fasteners (nut and bolt) a good glue will yield several advantages. A prime consideration is weight aloft. After you count up hundreds of fasteners on a lengthy built up mast, the weight will make you sweat in the first real blow the stick sees. Fastener arrangement, as has been mentioned, can cause a host of issue, like trying to screw a sail track down and having internal fasteners get in the way. Hard points and stress risers are another issue. the fasteners create a localize clamping force that rapidly decreases as you get further from the fastener. Under bending loads this can place surrounding wood under undue stress, causing localized fiber failures. This can be commonly seen as compression around the fastener heads or distortions in the general area, both weakening the mast.
Applied properly, glues can generate a uniform bond between pieces, stronger then the fibers themselves. This makes a homogeneous column, one that will react uniformly to load, not the dictates of fastener spacing.
Some masts, box section in particular, will have small brads to hold the stave's in place while the glue cures. These offer little to no structural advantage other then initial alignment.
Chapelle used and wrote about truly waterproof glues, including resorcinol, plastic resin, which he was fond of and epoxy, which he wasn't completely convinced of yet. He passed in 1972 and was well aware of the "new fangled" goo's.
Old 07-07-2009, 12:37 PM
Rep: 1397 Posts: 7,215
Herreshoff was using "plastic" glue for spars in the 1920's already. Chapelle's book is of much later vintage.
Gluing Teflon mikereed100 Materials 12 12-04-2008 12:28 PM
Gluing vertical pieces crosscut Wooden Boat Building and Restoration 15 03-10-2008 01:24 PM
gluing teak dsmolar Fiberglass and Composite Boat Building 8 02-24-2006 04:22 AM
gluing to aluminum? thadJ Boatbuilding 8 12-17-2005 12:31 PM
Gluing pvc foam core Boatbuilding 4 02-12-2003 03:25 PM
