Old 04-18-2008, 05:47 AM
hasani hasani is offline
Rep: 10 Posts: 8
Propeller Selection
I want to choose a propeller for a tug with the following particulars:
Main engine power(single screw): 3300bhp
RPM: 600
Gearing rate 1:2
which want to tug a 5000 tonne weight in 6 knot speed. and does not have kort nozzle.
please inform me about the specifications of the best propeller which can satisfy my needs. i want to know the type, No. of the blades, and the diameter of the propeller.
Tnx
Old 04-18-2008, 06:13 AM
Previous Member
Rep: 0 Posts: 0
How many threads are you going to create for the same question? it makes it extremely confusing for people who respond to follow other responses?
Rick W.
Old 04-18-2008, 11:11 AM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
With all these threads maybe he can knit himself one?
Old 04-18-2008, 08:41 PM
artemis artemis is offline
Steamboater
Rep: 267 Posts: 411
RPM: 600
Gearing rate 1:2
Tnx
Visit the website of one of the many propeller manufacturers (google the name), fill out their form and email it. You'll get an answerback in a day or two.
Old 04-19-2008, 01:58 PM
safewalrus's Avatar
Ancient Marriner
Sound advice there artemis - for all of us
read it as you may, I know art will read it the way it is intended!
Old 04-19-2008, 02:37 PM
Steamboater
Rep: 267 Posts: 411
Thank 'ee kindly Walrus. I've left a little tip for 'ee
Old 04-19-2008, 04:20 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
Hello...
Hello...
See attached - if it works...
You first need to determine your shaft diameter - bearing spacing if more than one in the log - and your available hull clearance - need 15 to 20 percent of wheel diameter so as to not cavitate at the top of the swing ...
Here is a good site - an old friend even - see http://www.bertram31.com/proj/tips/shafts.htm ...
That gets you started - as for material and section thicknesses for a tow application - talk to a good maker that have their own foundry and machine facilities - like http://www.osbornepropellers.com/Consulting.htm ...
These guys have been casting and milling their own product since the 1930's...
All pretty basic stuff - from this point it can get crazy...
SH.
propeller selection gharai Jet Drives 1 12-22-2007 05:02 PM
Prop Selection CMARSHALL Props 3 07-03-2006 05:44 AM
Prop selection again simso Props 5 08-31-2005 04:54 AM
rivet selection Seaspan Boat Design 5 04-06-2005 09:49 AM
Prop Selection TJB621 Open Discussion: All Things Boats & Boating 0 02-07-2004 04:52 PM
