Old 06-27-2011, 09:59 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,834
power tools
What that new saw?
It looks like a jig saw but the blade sticks out the front and sweeps left and right ( depending on how you hold it) rather than goes up and down like a jig. Ive seen a guy use it on the telly to make a nice neat hole in some plaster board.
I can't find it on the internet but then I don't know what they call it.
I would like one to cut neat, less dust holes in fibre glass for interior work.
Old 06-27-2011, 10:10 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
I think they're called "oscillating" saws. The Cdn version is called Multi-Max.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 06-27-2011, 10:15 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Afternoon Frosty ,Bosch PMF180E offers the best DIY value in this very versatile tool ,wouldn't be without it.
Old 06-27-2011, 06:37 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
Are you sure that's what you really want it for Frosty?
You could fit your own oscillating attachment on the end, or am I leading you a bum steer.
Old 06-27-2011, 06:50 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Like a roto-zip?
Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR
Old 06-27-2011, 07:11 PM
Saildude Saildude is offline
Rep: 92 Posts: 77
The saw blade sweeps back and forth sideways - quite handy for certain apps and you can get sanding pads for it and it will get into corners nicely.
Old 06-27-2011, 08:43 PM
Frosty's Avatar
I want to modify a bathroom window on the boat. I don't want to grind it out or as you can imagine we will be in a snow storm of fibre glass dust, whos gonna wanna take a shower in there.
Fine controlled cutting and sanding sounds good.
Old 06-28-2011, 05:06 AM
Rep: 3120 Posts: 9,376
Bolt a oscillating blade to a detail sander and you've got a home made, saw as you've described, without forking out lots of bucks.
This is a Dremel brand blade bolted to a Ryobi detail sander. These tools are called "Multi tool" by several brands. Harbor Freight sells two versions of this, one 40 and the other 60 bucks. Mine works as well and the blade cost $10 and I had the two #6 machine screws and lock nuts in house. It still works as a detail sander, which is a tool I rarely use anyway.
Old 06-28-2011, 07:23 AM
bntii's Avatar
bntii bntii is offline
Rep: 1073 Posts: 704
Yep- the oscillating tools like the Fein & clones all do as you ask with a cut blade: controlled cutting through GRP without throwing the dust all over.
My Fein has been a workhorse for many years but is the most $ of the bunch.
http://www.amazon.com/Fein-MultiMast.../dp/B000U8S3QA
Old 06-28-2011, 07:30 PM
Looks like a patented tool you've copied there Par.
Old 06-28-2011, 10:42 PM
Actually the patent has run out on this particular novelty and modifying a tool with a different blade isn't copying, though it does employ some features seen in other tools. I have several dozen home made tools, some certanily taking desirable features from other things I've seen. It's a good thing the wings on aircraft patent has run out or there would be an awful lot of helpless passenger airliners.
Old 06-28-2011, 10:58 PM
Frosty's Avatar
But how do you know if it does the same thing maybe the travel is different.
A sander does not move that much , but a saw has to cut.
Maybe I could just fasten a blade onto my phone on vibrate.
Old 06-28-2011, 11:34 PM
Rep: 92 Posts: 77
Yes Frosty - once a Mechanical Engineer always a Mechanical Engineer - hard to hide the roots and history
Old 06-28-2011, 11:40 PM
Frosty's Avatar
Ive just looked at this being used on youtube --it seems very impressive and when it stops raining.......
Maybe Mohameds tool emporium may have one. Bosch of course,--only bosch, I cant kill a bosch, yes there maybe better but for me the price is right and the tool works fine unlike Black and Decker which should be banned from the market.
Makita in Thailand carries no warranty, yup Bosch for me.
Old 06-29-2011, 02:13 AM
Rep: 241 Posts: 391
If you do buy Bosch, make sure you get a metal cutting blade ,the ones for wood won't last. Some of the earlier Fein blades will fit ,but I was given a new set recently that won't ,check before you buy.
Anyone know what these tools are?!?!?! jrbackus Wooden Boat Building and Restoration 50 10-08-2010 09:27 PM
Power tools wudenbote Wooden Boat Building and Restoration 36 08-30-2008 12:58 PM
old tools lazeyjack Wooden Boat Building and Restoration 74 08-13-2007 09:41 AM
Grizzly Shop/power tools bjl_sailor Wooden Boat Building and Restoration 3 11-09-2004 12:34 PM
tools Jorgoz Boat Design 3 02-06-2003 11:59 AM
