| plastic or carbon prop I am building a pedal boat, and I am in need of a propeller. I would like to use a plastic or carbon prop. about 10 to 14 inch dia. 2 or 3 blade, with a 1/2 or 3/4 shaft opening. does antone have any idea where I might find such a thing ? new or used ? prop will have a small load onit- human powered. Thanks Rusty |
| A 10-14" prop is too small to be efficient for a HPV. Most of the one's I've made and seen are larger. Go to the IHPVA site (www.ihpva.org) and check out the water vehicle chat sites. Maybe someone has a spare/old wheel they would part with. |
| The 6-blade plastic fan from a 1980 Ford Escort works surprisingly well! ![]() Steve |
Rusty |
| Rusty - I should probably have stated that this was in England, where the Ford Escort hsa bneen around for far longer than in the States... Sorry. The boat in question was in a local "holiday" human-powered boat race. Not extremely technical, but the boat was about 12', very light and skinny sort of proa design. The prop was quite efficient, but the strut needed to be aft of the prop due to blade bending. Iwould recommend a skinny layer of carbon on the aft faces of the blades to stiffen. The diameter was about 12", and since they were using a short chain in their drive-train, they were able to increase the rpm over what the "powerplant" could provide on a 1:1 basis. Steve |
| e-glass vs. aramid/kevlar vs. carbon | JEM | Materials | 12 | 06-12-2005 04:19 PM |
| Carbon mast construction in 2 female 1/2's | bjl_sailor | Fiberglass and Composite Boat Building | 4 | 05-01-2005 12:30 PM |
| sea ray prop for planing | jfc52 | Propulsion | 20 | 09-17-2004 09:09 PM |
| Ideal depth of prop/ surface peircing props | Sonnie00 | Powerboats | 2 | 08-01-2004 08:01 PM |
| carbon monoxide boating deaths | Guest | Open Discussion: All Things Boats & Boating | 7 | 10-28-2003 09:51 PM |
