#31
| Walrus I thought of a million things that could go wrong, so decided the safest thing to do is stay clear of the rig. You are correct, ascend to quickly, and you will suffer the bends, and could die. I was most afraid of the door coming loose from the chain, or the drum rupturing, and then helicoptering down on top of us. we swam a fair distance laterally to be safe.
__________________ Tom |
#32
#33
| Tom, you are keeping half of Europe awake! The next 10 minutes I'll be in my car, when I come home I hope you have another hint :-) |
#34
| Ragnar, Now I can't just give away the answer. Read post # 30 again especially quote 2. Just as with a boat you can't design for just static states of equilibrium, I too should have thought more carefully and considered dynamic forces.
#35
| Now at home with wine and cheese :-) ... I think the speed was so high the the door jumped out of the water, up in the air, and made some sort of problems. |
#36
| Hmm, the drum is very light compared to the door... /RT |
#37
#38
| Damn, I couldn't get back until now. I'm glad I was close :-D I can just imagine you trying to move all that mass while wearing flippers. |
#39
| I am beginning to think that this is not a case of what did I do wrong with the imformation that I have given you, or with the applied priciples, rather than what did I do wrong that I haven't told you about. This could include not filling up your own cylinder with air before descending or forgetting to put on your boyancy jacket. For example, nobody that I know that does this sort of activity would drop drums down anywhere near the object you want to surface and then drag them across the ocean floor. They attach a line to the object up to the boat so the drums sink down to where the object is. I know you left the bungs out of your boat so half way up the door met your boat on the way down. |
#40
#41
| Man Overboard, I am thinking you would have had to move a couple of hundred pounds of water 10' across the bottom, while you have almost zero bouyancy... Like a butterfly pushing a brick... While salvaging a 30' boat in 30' of water, my friends and I came across the same problem. We used a 20lb anchor on the drum(44gal) and pumped in a little air to get ours off the bottom and swam them around. Last edited by rayk : 01-27-2007 at 12:44 AM. Reason: bit slow in posting.... |
#42
#43
| We had to figure it out after sinking the first ten drums in a big heap.....not too close to the boat, dont want to ding the wreck up.... The rest slid down a rope tied to the rails on the other side of the wreck. It seemed such a simple plan.... |
| section modulus brain fart | oceangboy2000 | Boat Design | 7 | 04-01-2006 09:21 AM |
| Boat Design using toothpicks for Physics Project | tpru2000 | Boat Design | 4 | 05-16-2005 09:46 AM |
