| okay, i admit it... i'm technologically challenged. would someone please explain to me how to post an image...... in layman's terms... . . . . .. thanks _/) |
| The easiest way is to click on the "Choose" button in the "Attach File" section at the bottom of the post reply section. This will open a dialog box on top where you select the file from your local hard drive, you click the "open" button (depending on the OS) which selects it. And that's it - the filename will appear in that little box next to the choose button and the attachment will appear with your post. Notes:
| And you are also always welcome to post some images in the gallery which works very similarly to the forum. If you visit the gallery using the subdomain (gallery.boatdesign.net instead of boatdesign.net/gallery) you might have to login to the gallery initially but the login should hold after that. |
| Jeff, since you know how, what do you do to take "Screen shots"?? I at a time knew..... |
| On a Windows system, you can simply hit the "print screen" button on the keyboard and it will take a screen shot and copy it to the clipboard from which you can then paste into an image editing program to save for the web as a .gif or .jpg. If you hold down the Alt key while hitting Print Screen on the keyboard, it will take a screenshot of just the active window rather than the whole screen. |
| thanks Jeff ... muchly appreciated!!! |
