| New to the forum, trying to restore a skiff I figured I would do an introduction thread. So, my name is Ben and I'm a surfrat who spends most of his free time fishing from the surf. I specifically target striped bass and do pretty well at it, mainly fishing on the ocean from sand beaches, often fishing from a jetty, and sometimes fish the back bay. Wherever the bass are. So a good friend of mine gave me this 16' skiff. I was thinking about fixing it up and doing some fluking next year. But with the amount of work it needs I'm not sure if its worth it, hopefully you all can help me decide. ![]() ![]() ![]() ![]() My friends father owned a boat rental company in the 60's that rented skiffs in the bay. Someone took one of the wooden skiffs and used it as a mold and made 10 fiberglass boats, this being one of them. My friend had hopes of restoring it and using it. Unfortunately he needs to clean his house out as he must sell it... He is going through many personal issues. As you see he also gave me some outboards with the boat. But both being 18hp they are probably to big? He said the max they used to use with the wooden boats were 9hp. So as you see someone cut out the seats (for an unknown reason) and lost all of the structural support the boat had. I'm guessing my friend did this as he was explaining to me that the wooden boats has just two seats in the rear next to the outboard, and one seat near the bow. Leaving the middle open for fishing. I just don't see how this can be achieved with a fiberglass version and still be stiff. My plans were to use some straps (3 of them) and totally go around the boat, pulling the boat back into shape. It moves back into shape very easily with a little pressure applied from each side. After the boat was shored up with the straps I was going to fiberglass the seats back in place. Then I was going to cut a new transom and fiberglass that in place. Now what I see as being the breaking point in this boat. The wooden siderails! If that's what you call them? Obviously these are steamed wood put in a form to take the proper shape. As I see it not an easy task to reproduce.... I had thought about just using some c-channel rubber. But I assume this is a structural part of this skiff? Also, my uncle is a little worried that the numbers on the boat have been sanded off. My friend assures me that the skiff isn't stolen. But why would the numbers be sanded off? I know many times this happens when people abandon boats. I guess there could be many reasons. Should I be worried about this? Obviously before any work is done I will need to acquire a registration. Well I hope my first thread was long enough for you all. ![]() |
| The boat looks like a semi-dory (is the bottom flat?). I suppose you could build gunwales for it but you don't need to steam the wood. Laminate them out of 1/2" thick pieces instead. Three layers makes 1 1/2", which is about right. Many woods will do. I've done it with cedar, two 1/2" thick x 1 1/2" high layers on the inside, sealed with tape and epoxy, with the cloth wrapped over the top, and then oak on the outside, which covers the tape's edge. Quick and simple. Those 18 hp oldies may be alright for that boat. The transom needs to be checked out for internal rot (it's probably going to be plywood, molded in). once the transom is addressed, an 18 hp will get you up to speed--- that boat appears to be designed to plane at 15-20 mph, though others may correct me, I'm no motor-boater. You'll probably have to re-tab all the seats if one came out easily from flexing. I'd recommend epoxy for all repairs, for a good bond and consistant results. You'll probably be buying a gallon, and have some left over. |
So, amazingly I understand exactly what your saying for making new gunwales! Although it took a minute or so of thought! Using the 1/2" thick pieces will bend to my curvature without any steam? I suppose I need to lay each piece on individually, then screw them all together and through the boat? I assume each side needs to be made from three pieces spanning the while length of the gunwales? Or can it be in sections? The gunwales scare me the most on this project. If you could go into your method in a little more depth I would greatly appreciate it! The transom had two pieces of about 3/4" thick plywood lightly epoxied to eachother, and then epoxied to the rear fiberglass transom of the boat. You can see it out of the boat in the picture with the motors. So that seems simple enough to me. Two 3/4" marine grade plywood sheets cut, using the old transom as a template. Then I was thinking of doing a better job of attaching it to the boat, Then maybe totally covering it with resin? As far as the seats go. All the seats are currently not attached to the boat, someone cut them out. I just placed them in the correct spots to see how far the boat had spread without them as supports. As I said before, it didn't spread to far, and with a person on each side they can apply a little pressure to push the boat back in place. So epoxying all the seats back in place is my first step. The motors are pretty basic, and maybe I will end up using one. He said one ran before putting them in the shed. I do however have a friend giving me two newer evinrude 9.9 motors soon. Thanks again! |
| The rails mentioned only need the outer hardwood (outwales) screwed through the fiberglass into the two inner pieces. What ties the inner two (inwales) to the boat first is epoxy/clamps and then two layers of fiberglass tape, which wraps over the inwales and down the outside of the hull before the outwale is screwed on. This hides the edge of the tape under the oak strip. The pieces should be rounded a bit after clamping, and the outside edge of the fiberglass should be rounded off as well. You can drop the oak rail a half inch and reduce its height to an inch, making a step that is attractive. The fiberglass hull's top edge and the taped inwales are then painted to set off the oak rub rail's natural color. With this detail, the oak (or hardwood) rail should be a bit thicker than the two inner rails, maybe 3/4" thick. |
I have re-posted this thread. I was only going to use this thread as a small introduction thread. But I started typing away and it seems its in the wrong forum now. Hopefully this thread will go into nowhere land now, and the other thread can take over. Sorry for making a mess of the forum. Link to new thread; Skiff (semi-dory?) restoring |
| Jeez does that old thing bring back memories. As a kid in Puget sound, 1946, I discoverd one like that half buried in the sand and other drift wood way up in the logs above High tide. I struggled by myself for most of a day but finally got that thing down to the water. It was really dry too. Boy did that thing leak. I found a pole and moved it a mile or so up the beach. A reletive got it home and told me how to tighten it up. We (the family) used that boat for years. It's a great design for rowing while fishing. Very stable. |
cb900ss : That could be quite a nice boat when finished.The repairs are not that bad. Do what Alan said .... I would replace the whole plywood transom panel with new plywood.Use the old as pattern. One of those old outboards would look great on the back too. Nice low cost boat.
__________________ How big a reproduction are you thinking and do you have crew and money dripping off your butt?( PAR2009) |
| Some more experience to go along with BoatFan's "replace the transom" Several people have suffered when the transom came apart or broke off under the strain of small motors on bad water. Dont chance it. Replacing the Transom is pretty easy. Also make sure the part you clamp the motor onto is thick enough for the clamps to get a good grip on. I had an early F/glass boat. The transom was thin. We'd put a piece of plywood in there for a filler and clamp it down with the motor clamps. While under way, the clamps loosened up, the motor rotated right up out of the water and came after me....it seemed that way anyway, and I leaped out of the way, causing the boat to tip, and my uncle, who was looking the other way, fell over on the gunn'l and finished tipping the boat. It flipped, we lost the motor and nearly didn't survive that incident. Your boat is gonna row so easy, yo don't need a motor. |
| By the way, here's a couple links to converting your old Two-Hose motors to the newer and safer Single hose arrangement. http://www.sschapterpsa.com/rambling..._fuel_line.htm http://outboard-boat-motor-repair.co...el%20Tanks.htm |
| Restore project | pcmpete | Boatbuilding | 2 | 04-23-2009 03:58 PM |
| restore plywood boat | treeclimber@xtr | Wooden Boat Building and Restoration | 8 | 03-26-2009 09:11 AM |
| How to delete files in your gallery, forum rep points, forum attachment sizes | MikeJohns | Forum Questions and Suggestions | 10 | 08-18-2007 06:28 PM |
| '68 Mermaid commander restore | jlf4761 | Powerboats | 1 | 08-01-2007 08:05 AM |
| Help to restore timber boat | Jan Cruickshank | Services & Employment | 3 | 06-06-2003 06:27 PM |
