  #31
Old 06-28-2010, 05:08 PM
apex1
When you leave the chain, the light line and the foam balls you have the most common system in modern marinas.
But this is a neat solution and the easier handling balances the slightly higher investment.
Thanks Cornelis.
Richard
  #32
Old 06-29-2010, 08:12 PM
Stumble Stumble is offline
Rep: 599 Posts: 1,083
Richard,
For my boat in Jamaica we did something similar to what CDK did, but have three radial blocks chained to a central small block. The mooring (using dyneeme) line then attaches dirrectly to the center block. The non-stretch line in this application is offset by the central block that lifts as load is applied. It is complicated but works great, the boat has survived 3 hurricanes on the mooring without so much as budging.
I have looked at the helical ones, but driving them into solid bottoms is impossible, since the act of drilling out a hole for them weakens the bottom they are using to secure too. The other option I have seen in this situation is to drill into the bedrock then place steel rods into the hole, inject waterproof epoxy or concrete and attach the rod to the bouy.
Where effective I would imagine the helix would be easier to install, but its limitations won't let it work out for everyone.
Hazelett Marine: Elastic Mooring System WickedGood Marketplace 0 05-17-2010 06:44 AM
Idea for mooring "system" JLIMA Open Discussion: All Things Boats & Boating 3 04-30-2010 11:04 PM
favourite sea novels lazeyjack Open Discussion: All Things Boats & Boating 129 06-15-2007 12:13 AM
Old fashioned mooring system with floating pole ... kengrome Boat Design 6 05-05-2007 05:21 PM
What is the favourite or best Scientific calculator use by NA and designer? Wellydeckhand General Computing 25 09-19-2006 06:09 AM
