Old 02-24-2009, 01:32 PM
confused confused is offline
Registered User
Rep: 19 Posts: 155
Modified Hot-Bulb Engine
Well, I guess now that my steam launch thread has served its purpose, it is time to start a thread about something that is at least HALFWAY legal, and less expensive than the steam launch. So I have decided to tell you of my invention, unless you already know of it. (people like par and apex1 and rasorinc that were on my other thread). I guess I shall get to the bleedin' point of this thread. I have invented an engine that is almost indestructable. Yes! you could put WATER in the fuel tank and it wouldn't screw it up! it will KEEP running! you could PEE in the fuel tank and it would still run! you could put Waste Vegge Oil in the fuel tank and it will STILL run! you could put ANY liquid that is combustable (NOT NITROGLYCERINE!!) or can make steam in this engine and it will RUN off of it! well, I have drawn a sketch of it that took me a week to make, and it looks good! if it weren't on paper, it would run! (well maybe not, because it is a diagram, so it is cut in half). I wish I had a scanner to show you it. I will make a REALLY rough sketch of it on paint, just so you understand how it works.
Old 02-24-2009, 02:55 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Hi Confused,
With the stuff some of these sailors consume it may well run just from the air they breathe in a boat, any engine for that matter would Peeing in it may corrode the engine away
I like your spirit and keenness, keep at it, it will take you places
Regards
Fanie
Water ! Just gimme water !
Old 02-24-2009, 03:01 PM
Registered User
Rep: 19 Posts: 155
o.k maybe not pee, but it could run on all of that other stuff as long as it has a heat source to keep it from cooling when running on water.
You live in south africa?!
thanks
mike
Old 02-24-2009, 03:16 PM
Fanie's Avatar
Fanie
Some HOT chicks then. This is more to my liking, you may not agree now but when you grow up some...
I try to live here, off late it's not so cool. Much troubles brewing, almost like an engine with all the wrong spares you try to assemble.
Where's that picture you were going to post. I need an engine like that that runs on anything.
Regards
Fanie
Old 02-24-2009, 03:44 PM
Registered User
Rep: 19 Posts: 155
here it is:
Old 02-24-2009, 03:52 PM
Registered User
Rep: 19 Posts: 155
well? you need more than "HOT chicks" to heat the hot-bulb lol!
Engine stalls when at idle when hot partgypsy Gas Engines 5 11-30-2007 07:57 AM
Help me ID my new hull...16.5' fiberglass modified V... what engine/drive would work? ve7khz Boat Design 15 07-01-2007 08:32 PM
Modified Tigercat Ted Clarke Multihulls 2 12-18-2006 03:54 PM
Engine too hot seagums Gas Engines 5 08-09-2006 12:02 AM
Modified Deep V jfblouin Boat Design 4 02-14-2005 03:38 PM
