  #766
Old 01-25-2012, 02:21 PM
BPL BPL is offline
Rep: 209 Posts: 218
Originally Posted by peter radclyffe View Post
Thanks for the link Peter. Too bad the bottom isn't visible. And the recovery portion appears overly-simplified.
  #767
Old 01-25-2012, 02:41 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 680 Posts: 1,395
http://www.fincantieri.it/cms/data/p...urce3_orig.pdf
  #768
Old 01-25-2012, 02:45 PM
BPL BPL is offline
Rep: 209 Posts: 218
Originally Posted by Gian Milan View Post
However in 1912 they had all entrusted to the great designers that, having regard to considerations of traffic, given the numbers, all evaluated with great intelligence, thought adequate lifeboats for only half the passengers.
Something makes me think that the designers have had children and grandchildren.
How about naming some of these great designers of 1912 Gian?
Or that could be a good topic on its own.
  #769
Old 01-25-2012, 02:47 PM
BPL BPL is offline
Rep: 209 Posts: 218
Thanks for this PDF link Peter. The charts are interesting.
  #770
Old 01-25-2012, 02:57 PM
Gian Milan Gian Milan is offline
Previous Member
The Titanic was designed by William Pirrie and Thomas Andrewsby who was the chief designer.
By agreeing to remove a lot of lifeboats (for aesthetic reasons!) they have made ​​a mistake scary.
It is my absolute opinion that designers of Concordia, like their predecessors of Titanic, have designed a not safe ship.
But Andrew and Pirrie Have no previous experience.
So they are less guilty of their "grandchildren".
  #771
Old 01-25-2012, 06:28 PM
IEWinkle IEWinkle is offline
Retired Naval Architect
Rep: 184 Posts: 97
Originally Posted by nettersheim View Post
According to the delivery time the vessel has been built under SOLAS 90 rules. That means the deterministic principles have been used and based on this I suppose the vessel is a "2 floodable compartments".
I think you will find that for a ship of this size with as many passengers SOLAS 90 would require a '3 compartment standard'
  #772
Old 01-25-2012, 07:56 PM
masalai masalai is offline
masalai
Rep: 1882 Posts: 6,847
http://www.abc.net.au/news/2012-01-2...n-rome/3794044
Try to be helpful...
Remember that there are at least two sides for every story...
  #773
Old 01-25-2012, 09:07 PM
Petros Petros is offline
Rep: 1593 Posts: 2,938
Comparison to Titanic is not really valid (though inevitable). Very different deisign conditions, etc. A number of coincidences caused the accident, but Titanic ultimately failed because the designers had specified a new type of alloy that was both strong and tough, and allowed for a larger hull to be designed. The steel supplier could not deliver the quantities in time to meet contractual delivery schedule so substituted a different alloy without authorization. the alloy had the same ultimate strength but was brittle (did not have the same toughness). When it struck the ice burg the hull plates cracked open rather than just buckled, allow too many internal compartments to flood.
It went down fast, and ultimately the hull cracked in two. None of this was known until the wreckage was discovered more recently and it was found on the bottom in two pieces, and samples of the hull material was brought up and sent to a metallurgy lab. I had read a number of technical books when in collage on why it sank, all were speculation and none got it correct until the samples were tested.
You can only design for what you would reasonably anticipate, it would be far too costly to design for every stupid and inconceivable thing that MIGHT happen. Some fool will always find a way to thwart the best efforts of the designers.
The Concordia was ripped open on a rock, and almost everyone had gotten out. More would have gotten out had the crew had their act together it sounds like to me.
  #774
Old 01-25-2012, 09:24 PM
powerabout powerabout is offline
Rep: 719 Posts: 2,916
sounds like a Benetti built today
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
  #775
Old 01-25-2012, 09:27 PM
BPL BPL is offline
Rep: 209 Posts: 218
Did not hear about that accident powerabout. Do you have a link to the accident report?
  #776
Old 01-25-2012, 10:45 PM
Previous Member
Wade, W.C. 1986. The Titanic: End of a Dream, Penguin Books, p. 41:
....Alewander Carlisle,..... designed the Titanic, said: "Unless the Board of Trade and governments do not make it necessary to install a sufficient number of lifeboats, no manufacturer can afford so much useless weight"
After this post, here I think exhausted my contribution.
Thank you for the exquisite hospitality.
Greetings to all and ...Gonfie Vele!
  #777
Old 01-26-2012, 03:34 AM
nettersheim nettersheim is offline
Consultant
Rep: 152 Posts: 47
Hello Sir,
You are certainly right...
But it seems that sometime the "Solas 90" calculations lead to a "2 compartments standard" for similar vessel. We obviously need more information about that matter.
Guillermo in a previous post asked if somebody has info regarding floodable length for "Costa Concordia", which is clearly a related issue. I am afraid that we will not have answers to our questions shortly.
Have you an opinion on the list which has developped quite rapidly ? Normally, according to "Solas 90" no large heel should have been experienced (cross flooding devices... transverse watertight bulkheads... no longitudinal watertights bulkheads like in wing tanks or whatever without transverse connecting ducts, ...). Something has gone wrong after the collision. Actual damage size compare to "theoretical" damage size ? Too large free surface effect after flooding ?
Francois-Xavier Nettersheim
  #778
Old 01-26-2012, 06:04 AM
meaning any Benetti, they use high tensile paper thin steel
try dry docking one
  #779
Old 01-26-2012, 08:06 AM
Rep: 184 Posts: 97
I cannot agree with this analysis. The long raking damage to the Titanic's hull openned it up in a very similar way to that of the Costa Concordia. It is all a question of ship's speed and the energy of the collision and the fact that any riveted hull of that period would have split either at the longitudinal seams and/or by tearing of the plating in the same circumstances. All ship's steel of the time at the Titanic was relatively brittle at the temperatures then prevailing. It was not until after WW II that notch tough steels such as you would expect to see in the welded bilge structure of the Costa Concordia were widely applied and these are only applied to provide crack arrestors after the demise of riveted hulls.
You should also note that that the sinking of Titanic was 'slow and graceful' (as required as the basis for the SOLAS regulations derived from her demise) over a period of some 2 hr 40 min, which is a relatively long time for a vessel which is doomed to sink, and she sank upright without capsize! The fact that she ultimately broke in two after an extreme trim condition developed is not a matter of significant concern as ships are never designed to support such a large proportion of their hull unsupported by buoyancy.
  #780
Old 01-26-2012, 08:13 AM
Rep: 184 Posts: 97
I refer you to my post 10 on thread Simulating Costa Concordia
help with cruise ship jobs james1911 Services & Employment 2 02-08-2012
07:28 PM
Cruise Ship Stability Willallison Stability 10 02-09-2005
03:09 PM
Cruise Ship Project cruiserbrain Boat Design 0 03-26-2004
08:16 PM
Need help with cruise ship mathematical formulas cmc Boat Design 4 12-12-2003
12:30 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
