Old 12-21-2006, 04:27 PM
Lyle Creffield Lyle Creffield is offline
Rep: 10 Posts: 35
Keel Design
Hi
My question relates to reducing a 1.8 m draft, 3m toe, 3.3 mean keel length, cord of 300mm attached to a 14.2m LWL crusing sloop
By reducing the draft to 1.5 yet maintaining the ballast C of G the same
Wings - not new
simply a wing of 900mm total width, same cord, same length, same ballast C of G
Provided the vertical keel area and sufficient for direction stability
why not?
Old 12-30-2006, 11:01 PM
Rep: 1623 Posts: 2,343
Lyle,
Reduced performance to windward with more leeway. Problems getting hooked under coral at times and makes brute force towing off much harder.
The wings will add an end plate which can compensate to some extent for the loss of keel depth (but not that much). Usually when retrofitted they often add a lot of turbulance (drag) unless very carefully designed and that means tank testing.
I'd stick with the 6 foot draft on a 45 footer if you are planning for blue water .
Mike Johns.
Old 01-05-2007, 03:59 PM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
Except that you can't see the Reynolds number effects in a tank-test, and therefore you're getting bogus data. Wind-tunnel tests or CFD are your best options for optimisation. Niether are cheap.
There is a lot of information about reducing the draught of a yacht on this forum, I suggest you have a search around. I have expressed my opinions on the matter several times. In short, "It will cause a lot of problems. Do you really need to do it?"
Tim B.
twin keel design Tom Triglav Boat Design 12 09-28-2005 08:41 PM
Keel design issues HeloDriver Sailboats 45 01-03-2005 11:01 AM
Keel design questions olesprit Boat Design 5 10-04-2004 09:27 PM
keel and rudder design max Software 6 04-26-2004 07:43 PM
keel design max Boat Design 3 10-18-2003 04:33 PM
