Old 07-19-2005, 09:31 AM
stevebarrett stevebarrett is offline
Rep: 10 Posts: 2
Hydofoil question
Hi there,
I am hoping you can all help me resolve a debate I have been having with a friend. The basic question is...
"What limits the length of a hydrofoil?"
I am talking theoretically rather than practically speaking and for hydrofoils seen on dinghys such as international moths.
If the boat can produce enough lift to raise it out of the water by 30cm does it therefore also produce enough lift to raise it by 5m?
Do hydrofoils sit in a state of equilibrium under the water and if so what stops them lifting the boat higher i.e. so the foil is on the surface.
I'm sure i've not made myself very clear but I think i've got the rough idea across.
Old 07-19-2005, 10:25 AM
Skippy Skippy is offline
Rep: 12 Posts: 568
The efficiency of the upper surface drops as the foil approaches about one chordlength below the water's surface, until at the water's surface, the foil's upper-surface efficiency is zero and the foil is planing. So yes, there is an equilibrium.
Old 07-19-2005, 10:32 AM
Rep: 10 Posts: 2
Thanks for you answer..
What is a chordlength- does it differ dependent on the hydrofoil?
Old 07-19-2005, 11:33 AM
Rep: 12 Posts: 568
The distance from the leading edge to the trailing edge.
Hull enlargement question?? jackason Boat Design 3 09-09-2005 08:03 PM
Fiberglass Hull Liner Question Seadog Fiberglass and Composite Boat Building 7 08-14-2005 07:42 PM
Introduction and a Question AndyC Open Discussion: All Things Boats & Boating 16 07-13-2005 05:44 AM
Question re: "Voyaging Under Power" ccollar Boat Design 1 01-22-2005 06:43 AM
Planing hull question graham Boat Design 10 12-13-2001 05:40 PM
