Old 12-09-2010, 02:45 PM
bubbs247365
Help! Frozen Boat!
I live on the Kankakee River in the midwest and due to some unseasonably freezing temps the River has frozen over. MY BOAT IS STILL IN THE WATER. It's a Bass Tracker aluminum hull with a Mercury 40hp outboard, the river is frozen about 3 inches thick there near shore. We broke the ice up a bit around the boat and have it plugged in to keep battery charged. How much damage is this going to inflict on my motor or my boat? should i put a light or something in the bilge to unfreeze the water that i'm sure is in there? With the weather outlook i'm not sure my boat will be able to come out at all this winter, the ramp is about a mile down river.
Old 12-09-2010, 03:10 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Better get the boat out fast. I don't know how though.
Old 12-09-2010, 03:36 PM
bubbs247365
I did not find that comment helpful!
Old 12-09-2010, 03:38 PM
Rep: 3120 Posts: 9,376
Bubbles . . . lots of them . . .
Old 12-09-2010, 03:46 PM
bubbs247365
thank you all. I'll be deleting my account now.
Old 12-09-2010, 03:50 PM
alan white's Avatar
You get mad very easily. Bubbles will work if you can produce them below the boat somehow. If you drill a hole just upstream of the bow and rent a gas-powered compressor (wheelbarrow type), running the air hose into the hole and wide open, then when the ice around the boat melts, get a cross-beam 12 ft long tied across the gunwales at the bow, two men at each end of the beam to lift the boat up and onto the ice, then use outboard of boat to drive boat up onto ice, then pull to landing with skidoo, then break up ice and back in trailer...
Old 12-09-2010, 03:52 PM
Rep: 670 Posts: 2,457
Shouldn't be a problem. I operated 2 stroke outboard motors in heavy ice conditions for many years with no problem. The boat was in the water permanently, frequently frozen into thick ice. Ice damage to baots was caused when Ice Breaking ships cleared pack ice and compressed it into small craft ashore.
I assume modern outboard cooling to the similar that used to 30 years ago. Ask your outboard shop.
Old 12-09-2010, 06:00 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,350
Seems he didn't last very long. I thought bubbles was a great idea and have seen it before, in Popular Mechanics or somewhere.
Hoyt
Old 12-09-2010, 06:11 PM
CatBuilder CatBuilder is online now
Rep: 1320 Posts: 3,024
Right. That's what is used at many marinas when you live aboard your boat for the winter in a harbor that freezes. The marina deploys sunken hoses with compressed air streaming out to keep the ice away.
"You can't solve all of life's problems with epoxy" - My Wife
Old 12-10-2010, 05:51 AM
hoytedow's Avatar
Resistor
bubbs247365, you should come back and have a grown up discussion. We have not and will not tease you. This is a great place to learn and we all receive our share of good-natured(mostly) ribbing.
Hoyt
Old 12-10-2010, 05:54 AM
hoytedow's Avatar
Resistor
Do they not sometimes make a framework from galvanized pipe with drilled holes every so often shaped like a long rectangle?
Hoyt
Old 12-10-2010, 06:05 AM
hoytedow's Avatar
Resistor
http://www.tmpmarine.com/pages/bubbl...r_systems.html
Hoyt
Old 12-10-2010, 06:17 AM
liki liki is online now
Rep: 104 Posts: 167
Here someone recently used a chain saw to release his boat from ice. Made it into the local news.
At least one manufacturer also sells a circulation pump, but it must supported under water in a suitable position. It is used to circulate water a few degrees Celsius warm into surface on the position that must be kept open from ice.
Can you get a lorry with a crane near enough, there are cranes that are able to handle 1000kg over a distance closer to 20m installed in very regular lorries? Then you could just hack the boat free from the ice and lift it away.
With 3" ice I think you could also man-haul a trailer into the spot and pull the boat on the trailer over ice, but consider how you are able to secure the trailer in position for that. I wouldn't drive on the ice before it is at least 8". It could be that 3" is way too thin for a boat on a trailer?
Old 12-10-2010, 06:26 AM
hoytedow's Avatar
Resistor
If he could bubble some warm air under the ice he might be able to melt it even if it is 3 inches thick. Just drill a hole and shove in a hose, or several hoses.
Hoyt
Old 12-10-2010, 08:12 AM
Knut Sand's Avatar
Knut Sand Knut Sand is offline
Rep: 451 Posts: 506
We use that here... A hose attached to a holed metal tube laid on the seabed, below the boat, a small compressor (small, as in tiny, a 12 vdc car compressor may be ok for a emernency), and the bubbles will lift the warmer water up to the boat as they rise... To get that in place, you'll only need a rather small hole in the ice.
"Originally Posted by bubbs247365
thank you all. I'll be deleting my account now. "
But come to think of it, you don't seem to need an explenation to make your sound decisions... To wait this long to think of your boat...? (I've done that, but then I was thinking that the boat was "ok, sunk"... I also knew the work ahead to get it up/ running).
KnutS
"it's dark and we're wearing sunglasses"
frozen fuel pump push rod 7228sedan Gas Engines 12 06-01-2010 10:11 AM
Frozen water in bilge.. Adrian2 Boat Design 4 03-11-2007 10:59 AM
30 m mother ship for frozen tuna transport vishnubaiju Metal Boat Building 13 07-24-2006 02:52 AM
30 m mother ship for frozen tuna transport vishnubaiju Fiberglass and Composite Boat Building 0 06-02-2006 12:34 AM
Frozen Seacocks Barnacle Bob Open Discussion: All Things Boats & Boating 9 07-11-2005 08:51 AM
