  #31
Old 12-18-2010, 09:30 AM
SamSam SamSam is offline
Rep: 497 Posts: 1,679
I've heard that as a reason for the Titanic sinking, crappy steel rivets that became brittle in the cold water, broke under stress and opened up like a zipper. I have a low tolerance for cold water too.
  #32
Old 12-18-2010, 02:15 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
I can't imagine that the rivets would be any more brittle in 30 degree water than say 70 degree water. More likely the rivets were too soft since they had to have been peened over during construction. To peen steel it must be mild (low carbon), otherwise they couldn't have been peened over at all but would have shattered (or, if a bit too high in carbon would have be noticed breaking too often when being installed.
I could also be wrong, as I am not a metallurgist. These are just my immediate thoughts.
  #33
Old 12-18-2010, 03:02 PM
Rep: 3120 Posts: 9,376
Actually, you both are right. The Titanic's rivets where of a considerably inferior material, which did become brittle in cold water. There were several reasons for the ultimate catastrophic series of failures that resulted in her loss, but the biggest culprit would likely be the cold water brittleness of both the steel alloy used in her hull plates and the iron rivets. It's been found both the steel and the rivets failed by catastrophic brittle explosion. This is party explained by the speed of the impact and the water temperature, but more so by the chemical composition of both materials. Normally, you can expect some brittle failure in high speed impacts, but not the zipper like destruction found on Titanic. Normally, you have some plastic deformation, then tearing, before the material just erupts on a cellular level. Not with the steel and rivets used on this ill fated ship. These literally just exploded when suddenly highly stressed, so huge sections of seam opened up to the sea in fractions of a second.
  #34
Old 12-18-2010, 03:39 PM
Boston's Avatar
Boston Boston is offline
Rep: 1455 Posts: 3,350
ya the Titanic is an interesting lessons in what can add up to disaster
had the ship not turned at all but instead struck head on it would likely have survived
the tradition at the time was to "hurry" through the bergs rather than slow down and the weather kinda ganged up on them as well
there was an exhibit of titanic stuff that came through the natural history museum a while ago that was fantastic
lots of things contributed to the tragedy but the rivets being of an inferior material than the hull platting was definitely one of them
I am skeptical of the deniers diatribe
  #35
Old 12-18-2010, 03:45 PM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1004 Posts: 580
. . . and now the Titanic is eaten by a bacteria . . . ?
rust-eating bacteria . . . (Daily Mail, 7th December 2010)
New rust-eating bacteria 'destroying wreck of the Titanic'
A newly discovered species of rust-eating bacteria is eating the wreck of the Titanic, researchers say.
The micro-organisms, which have never been seen before, are helping decompose the famous ship at the bottom of the Atlantic Ocean, say the team.
They isolated the micro-organisms from a 'rusticle' collected from the ship - lying 3.8km below the ocean surface- and have named their find Halomonas titanicae.
The bow of the Titanic at rest on the bottom of the North Atlantic, about 400 miles southeast of Newfoundland.
Scientists say the ship's hull is under attack from a new form of bacteria
The researchers from Dalhousie University, Canada and the University of Sevilla, Spain, say the bacterium could pose a new microbial threat to the exterior of ships and underwater metal structures such as oil rigs.
The researchers, who published their findings in the latest issue of the International Journal of Systematic and Evolutionary Microbiology, also tested the rusting ability of the bacteria.
They found that it was able to stick to steel surfaces, creating knob-like mounds of corrosion products.
A similar process is thought to be responsible for the formation of the rusticles - which resemble icy icicles- that adorn the hull of the RMS Titanic.
While these appear to be solid structures, rusticles are highly porous and support a complex variety of bacteria.
The findings suggest that H. titanicae may be working alongside other organisms to speed up the corrosion of the metal.
Lead researchers Dr Bhavleen Kaur and Dr Henrietta Mann, from Dalhousie University, said: 'We believe H. titanicae plays a part in the recycling of iron structures at certain depths.
'This could be useful in the disposal of old naval and merchant ships and oil rigs that have been cleaned of toxins and oil-based products and then sunk in the deep ocean.'
They believe that the findings have opened up further areas of research that could be applied elsewhere, saying: 'We don't know yet whether this species arrived aboard the RMS Titanic before or after it sank.
'We also don't know if these bacteria cause similar damage to offshore oil and gas pipelines.
'Finding answers to these questions will not only better our understanding of our oceans, but may also equip us to devise coatings that can prevent similar deterioration to our metal structures.'
Setting out on its doomed maiden voyage on 10 April 1912 from Southampton to New York City, the Titanic was made up of 50,000 tons of iron but has now been progressively deteriorating for the past 98 years.
Cheers,
Angel
  #36
Old 12-18-2010, 07:20 PM
I don't think this is the case. At the speed she was traveling, she would have stuffed the bow past her fore mast, opening up enough compartments to flooding to sink her nearly as quickly. She would have flooded down both sides, maybe even sinking faster. I suspect damage back to the #6 hatch (at least, possibly as far back as the #5 hatch) and well past the 3rd class companionway stars would have quickly took her down.
No, the prudent skipper slowed and steered south, but with the recent advent of fast Atlantic transit, a complacency took hold of many skippers, particularly in light of the relatively trouble free transits that were occurring at the time. Several years of event free crossings and a belief that technology has made it so safe, that man was hardly required to helm the boat.
The rivets and the steel alloy where to blame for this level of damage from the impact. The steel didn't deform and fold, it shattered along the rivet lines and the rivets also didn't stretch and deform their heads, they just crumbled. Again, some of this was a result of the speed of the impact, but most of it was from the quality of both the sulfur laden, low carbon steel and the poorly made iron rivets.
  #37
Old 12-18-2010, 08:32 PM
Boston's Avatar
well this got interesting quick
yes it was the rivets and the spacing of the rivets that did her in and yes another skipper on the same rout at aprox the same time did steer a different course and slow his speed but Titanic was on a maiden voyage and the captain had been instructed to try for a record passage.
I've read a number of times that the ship would likely have survived had it only hit head on rather than a glancing blow down the length of the side. Given how much I've read about Titanic I should have started a thread ages ago about it
"Edward Wilding, the senior Naval Architect under Thomas Andrews at Harland & Wolff, testified during the British Board of Trade (BOT) Enquiry that in the case of a head-on collision, the bow of Titanic would have deformed much like the "crumple zone" of a modern automobile. This crumpling would have dissipated much of the force of the blow by spreading it out over several seconds." [http://www.encyclopedia-titanica.org...php/1511.html]
Apparently this would have created a much different scenario, particularly because it would have limited the flooding to the forward "watertight" compartments. "Bruce Ismay stated in America that the company had been anxious for the ship to afloat with any two large watertight compartments flooded; with four forward compartments flooded, the ship would probably also have floated in reasonable conditions." [http://www.encyclopedia-titanica.org...64/10340.html] Since on the night of the collision the sea was dead calm with no wind (which contributed to the difficulty of seeing bergs), Titanic could presumably have stayed afloat with four of the forward compartments flooded.
Unfortunately, when she scraped along the side of the berg rather than striking it head-on, Titanic's hull was damaged in such a way that more than four compartments were flooded, so the "conventional wisdom" is that had she simply rammed the berg with her bow, she might well have survived, though we can never know for certain.
If you're interested in researching this issue further, here are two excellent sites with considerable information:
The Titainic Inquiry Project [http://www.titanicinquiry.org/] offers complete transcripts of both the American and British inquiries into Titanic's sinking.
The Encyclopedia Titanica [http://www.encyclopedia-titanica.org/index.php] offers an amazing wealth of material, including extensive message boards, well-researched articles on a wide variety of Titanic-related topics, passenger and crew biographies, and a number of other valuable resources for anyone interested in Titanic's fate.
Read more: Would the Titanic still have sunk if it had struck the iceberg straight on instead of trying to go around it? | Answerbag http://www.answerbag.com/q_view/8912#ixzz18WMHJVXR
cheers
ps
by the way Par its good to have you back
hope all is well for the holidays
B
  #38
Old 12-18-2010, 08:44 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,938
That much ship at that speed hitting an object of such mass... not good at any angle.
-Tom
  #39
Old 12-18-2010, 10:16 PM
aka Terry Haines
Rep: 1811 Posts: 3,006
This new member never understood that he was getting a valid suggestion. He must have been desperate in this situation; it would have been difficult in such circumstances to clam down and check out Par’s somewhat cryptic post with a simple Google search. Some of us have been tempted to quit the forum at times. Nonetheless, 1 hour and 1 minute from first to last post must be an all time record that will certainly take some beating. Moving on ...
He’s gone now so we can’t help him, but it’s an interesting problem. First thing I would do would be to rescue the motor while the ice is thick enough, then unload the boat if it's not already done.
Bubbles are supposed to bring up warmer water but the effectiveness of that would depend on depth of water - if there’s deeper water further offshore the warm water would be out there - so bubbles might just reduce the buoyancy of the water and lower the boat more firmly onto the surrounding ice IMHO. I would think he’d want to raise it. It might be smart to buy a bag of water softener salt, dump it into the bilge water, wait for that to melt then pump it out. Then he could at least check for leaks; the boat would probably pop up all on its own if it still wanted to float. But then what? Still surrounded by ice - although he did note that he had been able to break it up to some extent.
But I really don’t know about this kind of problem. First thing I would do is ask the forum membership for advice. Er, yeah ...
I hope he was able to solve his problem.
Dances with Turkeys
  #40
Old 12-19-2010, 01:49 AM
mark775
I have been washing and breaking a lot of ice the last few days. Because of this thread, I have observed closely how it washes.
First, I was somewhat mistaken in that water movement alone would destroy the ice (afterall, haven't we all used frozen rivers as hiways?). I think enough movement eventually erodes it but an outboard on his skiff likely would take too long.
The mechanics of how the ice breaks from a stationary boat with a propwash are that wash gets on top of the ice and with a little time weighs the ice down until it catches full flow of the propwash. At this stage, the ice folds under itself and breaks in pans, size depending on how much thrust is applied. Eventually, with a gentle flow that does not get on top of the ice, it erodes, and I did this two days ago, with a near boatsized chunk one half boatlength back, breaking out and leaving a hole. How much flow and shaft downangle dictates how far back this hole forms. I had to, in four inches of sea-ice, break it manually for four feet behind the boat in order for the water to get on the ice and fold it under from the weight.
If ice gets under the main plane of ice and prevents water from weighing it down, the process is purely by erosion unless you can mechanically get something to dislodge it, rev up and blow the sheet away, of hit it with the boat.
Transom sterned, I can't back through more than an inch or two of soft sea-ice. Today, I nosed into some pans four to eight inches thick and was able to nibble away substantial leads Four inches is about the practicle limit for a boat of my size. Maneuverability is almost nil until a little room for movement is attained. Problem is, if you nibble two large of a chunk, the shape of the boat directs it righ back into the same slot it carved the last time. The key is to nudge gently, and break off small chunks, then wash them away until you have enough room to turn.
Those catamarans behind me tried to get out today and can really only go straight ahead, concentrating ice between the hulls and seemingly directing it at the drive units. I broke ice for the cats departing and returning, as they are near helpless in much ice.
Re: the frozen skiff, I now feel that I would get some salt around the outboard, get the outboard off and then worry about the boat. The ice won't hurt it unless a river or other boats or wind is pushing it around.
  #41
Old 12-19-2010, 06:13 AM
Boston's Avatar
I wonder if an exhaust gas bubbler could be rigged to help melt off some ice
  #42
Old 12-19-2010, 03:19 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,350
We could put a coil of tubing over a wood fire or some other CO2 source to pre-warm the air before it goes into the water, warming the ice and the globe at the same time, thus delaying the onset of the ice age.
Hoyt
  #43
Old 12-20-2010, 04:27 AM
Knut Sand's Avatar
Knut Sand Knut Sand is offline
Rep: 451 Posts: 506
Around here, we use boats until the ice is too thick... Its gives some added stress to boats that they're not originally intended for...
1; One earlier work mate, had a wooden boat, pine hull, thin ice... He later said that in his life time he'd never so far had experienced anything that cold, nor did he ever expect to experience or survive, anything that cold, at any stage, later in life... (An oak hull is safer in thin ice...)
2; A funny one; one I know had always had boats with outboards, in thin ice the propeller housing willl act as an "achor" in thin ice.. Well, on a sheer impulse, he bought himself a boat with waterjet, we were waiting on the quay/ boardwalk, a pretty high construction on piles in the water. Thin ice, near the shores, cold weather, no wind, a perfect day... He came at full throttle, towards us, then suddenly the ice was strong enough to carry.. Sea ice is pretty strong, in an elastic way. The boat had no "anchor" as a boat with an outboard engine would have had. He had a really convincing speed, when eventually sliding under the quay/ boardwalk, we heard him swearing and hitting almost every pile underneath... (shaken AND stirred, someone talked something about the last ball on a snooker table...).
KnutS
"it's dark and we're wearing sunglasses"
frozen fuel pump push rod 7228sedan Gas Engines 12 06-01-2010 10:11 AM
Frozen water in bilge.. Adrian2 Boat Design 4 03-11-2007 10:59 AM
30 m mother ship for frozen tuna transport vishnubaiju Metal Boat Building 13 07-24-2006 02:52 AM
30 m mother ship for frozen tuna transport vishnubaiju Fiberglass and Composite Boat Building 0 06-02-2006 12:34 AM
Frozen Seacocks Barnacle Bob Open Discussion: All Things Boats & Boating 9 07-11-2005 08:51 AM
