| Handy Personal Link Thread This wont interest most people - but I thought I would assemble a list of threads that I think will be helpful for my project. I will add to these over time. First List : Trim Tabs Trim Tabs information needed Lifting Strakes Lifting Strakes Strip Planking http://bowdidgemarinedesigns.com/Bow...ng_Videos.html |
| Building Methods Manies build - similar method (3.1) Manie's Microcruiser Manies re-inforcing with carbon Fibre (3.2) Last edited by rwatson : 11-27-2011 at 10:56 PM. Reason: info |
| Dual Outboard Control |
An example of water ballast holding drinking water |
| Fitting Windows http://www.thecoastalpassage.com/windows.html 1) paint Lexcan overlap on the inside. 2) Hold in place with 3M VHB 4991 which is 2.3mm thick, he was given the similar but thinner variety. The 1.1mm variety is more common but the right stuff is 2.3mm thick. 3) You need a silicone of the correct colour (black in my case) with a neutral cure. If using Perspex you may get away with only a 20% + or- joint movement capability. With lexan or polycarbonate you need more because it's rate of expansion is greater. I found the right stuff at “Lincoln Sentry” in Mackay. It is Dow Corning brand, silicone # 791 with a whopping movement rate of 50%!. The Dow material is intended for the construction industry. Those glass and steel office buildings use very large panels of glass. Because of the size of the glass, they can expand a lot and this silicone is intended to tolerate that. |
| Sail Shapes and Performance |
| PVA Application for Release in Moulds |
| Great Fibreglass Hull Fairing Tips |
| Some valuable info was passed in the shaft tunnel thread. |
| Trailer Design, and Quality Australian Braking Systems Some good ideas on trailers at Trailer usage for launching including bronze coated hubs http://www.titanbrakes.com.au/ |
| Calculating Power for Engines |
| Hull Resistance Calculations |
| Repairing Cored Hulls |
| The Missing Link | icetreader | Boat Design | 3 | 09-03-2011 02:24 PM |
| Handy Engine Sizing Formula | Bahama | Diesel Engines | 15 | 08-30-2010 02:17 PM |
| Handy Foam "How To" from bateau2 | rwatson | Fiberglass and Composite Boat Building | 2 | 02-15-2010 07:31 PM |
| Handy Andy Folding Boat | shakeyj | Wooden Boat Building and Restoration | 3 | 05-02-2006 04:34 PM |
| interesting link | Polarity | Boat Design | 0 | 03-01-2003 04:43 PM |
