| Outboard Prop Tuning An interesting link here on setting up a prop on a boat. "The Secrets of Boat Setup" http://www.kencook.net/Setupart.html |
| Mast Calculation |
| Finishing Epoxy Hull |
| Composite Design Publications |
| Useful Resin/Catalyst reference tables |
| Scarf Joint Diagrams and discussion |
| Overhead Epoxying Tips - with neat glove trick Some good advice on how to lay FG overhead with the least amount of pain including - Wear multiple layers of gloves, so you can pull the top ones off when they get too gooey, and not have to wrestle new ones onto your sweaty/sticky fingers. PS I keep a canister of talcum powder handy for fast and easy glove-ups. You cant have too baggy a glove, as sometimes its easier to use your fingers tips to manipulate goo. Overhead Epoxy Work Last edited by rwatson : 12-31-2012 at 07:35 PM. Reason: speeeling |
| Late night Peel Ply reading The Effect of Peel-Ply Surface Preparation Variables on Bond Quality Federal Aviation Administration http://www.tc.faa.gov/its/worldpac/techrpt/ar06-28.pdf |
| Epoxy users Health Protection Quote:
I liked that one Mike. I thought this thread on health protection should be a priority too Epoxy allergies - options? |
#25
| Stability for my Simple Mind center of buoyancy, or CB) and the center of all weight (vertical center of gravity, or VCG). a maximum righting moment = (GZ) GM is the measurement (distance ) between the VCG and the Metacenter (M—the point at which a vertical line taken from the heeled CB crosses the vessel’s centreline) Having said that, for a mono-hull yacht that is expected to do extended coastal cruising, open ocean cruising, or any vessel that is expected to be caught out in really bad weather you should look for the following; • a minimum range of stability to 90° of heel and over 120° preferred • a maximum righting moment (GZ) that occurs after 30° and preferably after 50° • and a GM of at least 2 feet and preferably between 3 feet and 5 feet GM is the most valuable number to consider, as it tells you the initial sta- bility; the stability that you will notice day to day. GM is actually the measurement between the VCG and the Metacenter (M—the point at which a vertical line taken from the heeled CB crosses the vessel’s centreline) as shown in this diagram. Low GM means the boat may be a bit tender to walk around on and heel a few degrees under wind pressure. How-ever, there may be a good overall range of stability, which you can check by looking at the Critical Angle or Ultimate Stability. If it has a higher GM then more than likely there will be sufficient initial stability, and possibly too much, however Ultimate Stability may be low. The boat will have a quick jerky motion in a seaway but be very stable at the dock. http://www.trekkeryachts.com/pdf/StabilityBray.pdf |
#26
| Hull Protection options |
#27
| Quote: http://www.diabgroup.com/europe/lite...re_bedding.pdf
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| The Missing Link | icetreader | Boat Design | 3 | 09-03-2011 03:24 PM |
| Handy Engine Sizing Formula | Bahama | Diesel Engines | 15 | 08-30-2010 03:17 PM |
| Handy Foam "How To" from bateau2 | rwatson | Fiberglass and Composite Boat Building | 2 | 02-15-2010 08:31 PM |
| Handy Andy Folding Boat | shakeyj | Wooden Boat Building and Restoration | 3 | 05-02-2006 05:34 PM |
| interesting link | Polarity | Boat Design | 0 | 03-01-2003 05:43 PM |
