Old 07-22-2007, 11:51 PM
nancur373 nancur373 is offline
Rep: 15 Posts: 11
Glass Mould Over Wood
I want to build a fibreglass version of my friends boat. I want to glass over its hull then remove the shell. I need some pointers like how thick should the glass be and how to make it structurally sound how to make the glass not stick to the wood etc. Thanks.
Old 07-23-2007, 10:51 AM
Rep: 15 Posts: 11
I heard of several people here in NF doing it but don't know anyone in particular. I do know it can be done.
Old 07-23-2007, 10:56 AM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Anything that would keep the shell from coming off the mold/boat would obviously have to be removed. Then I would assume the entire mold/boat would need a suitable wax liberally applied. You still might end up with the glass stuck on the boat for eternity. Plastic sheeting might work, might melt to.
Hopefully one of the glass experts will answer one of your posts. Just post once next time as multiple posts are discouraged.
Tim
Old 07-23-2007, 12:19 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
I think double thickness plastic (after experimenting to ensure the plastic does not melt) would allow easy release. The idea is sound, producing a boat ever so slightly bigger.
I would do one side at a time and set up a female mold to cradle and align everything afterwards. I would copy the original boat's thickness in the initial lay-up and then add in the same reinforcements after setting up in the cradle?mold.
No reinforcement or added thickness should be done prior to the first layup stage, the transom should be seperate (though it too can be done in the same manner as the sides), and then all is flopped into the waiting mold/cradle for assembly/completion.
Some fairing will be needed, but a neat job should make this a relatively simple task. It would help if the donar boat was carreened to allow the two sides to be successively as horizontal as possible.
I like the idea. I don't know about the legal issues, but I assume the class association rules would be broken if the boat is not exactly the same dimensions if such would apply.
Note: If the shrink-wrap film used for winter storage doesn't melt from MEK, it might be worth it to have that done for a relatively seamless job. Doing it in two halves allows wrapping around the other side, removing, and repeating on the opposite side. Reverse curves will present a problem, however. Depends on hull shape.
Alan
Old 07-23-2007, 02:12 PM
SamSam SamSam is online now
Rep: 464 Posts: 1,608
You want to make a mold from an existing boat, and then make a boat like that, from the mold? It depends on how big the boat is, what the finish is, the actual shape, especially as to negative angles, how long you want the mold to last, etc. Pictures help.
Or do you want to pull a shell off your friends boat and make that into a boat?
Old 07-23-2007, 02:17 PM
timgoz's Avatar
I think he wants to do the later Sam
Tim
Old 07-23-2007, 10:07 PM
Rep: 15 Posts: 11
Yes Sam. I wan to pull a shell off.
Old 07-23-2007, 10:08 PM
Rep: 15 Posts: 11
Thanks for all the tips so far guys
Old 07-24-2007, 12:30 AM
Rep: 95 Posts: 462
yes it can be done, my main concern would be the condition of your buddys boat, the surface will need to be quite smooth with no flaky paint, you might have to sand the boat down and repaint before you use it as a mould,
Glass Mould Over Wood nancur373 Fiberglass and Composite Boat Building 2 08-07-2007 12:05 AM
Glass Mould Over Wood nancur373 Boatbuilding 0 07-22-2007 11:50 PM
Glass Mould Over Wood nancur373 Software 1 07-22-2007 11:49 PM
Plastic or glass over wood??? ARGOS Boat Design 6 12-04-2006 07:13 PM
glass/epoxy over wood jomo Boat Design 4 11-22-2005 10:54 AM
