Old 02-22-2007, 10:54 AM
CraigK CraigK is offline
Rep: 10 Posts: 2
Floating a Golf Cart
Hey Folks,
I live in a community with 90 miles of Golf Cart Paths and over 10,000 registered Golf Carts. This is Peachtree City, GA if anyone is familiar with it. There are also two 250 acre lakes in the city where small craft are allowed, but propulsion is limited to electric (i.e. trolling motors). I’ve been toying with the idea for several years about building an amphibious golf cart that I can drive on the trails and directly into the lake.
I envision my amphibious golf cart resembling a WWII “DUCK” as are currently used by tour companies in DC, Boston and the Wisconsin Dells (where I’ve seen them). I could build the body/hull out of aluminum or maybe even aircraft composite (using Styrofoam as a mold).
All I remember about buoyancy is the craft weight will displace an equal amount of water weight. So how large with the body/hull have to be to support the cart which I imagine will be heavy with two adults, six batteries, electric motor(s), etc. I still want to be able to drive it on the cart paths with the many turns and twists.
I don’t envision starting this project for a year or so, but it will probably take that long to figure everything out.
Thanks in advance for your help.
Craig
Old 02-22-2007, 11:08 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
I think you just described an ARGO, in electric. The two stroke Argo's are supposed to be full of troubles and problems- but I think they are cool. Perhaps you could pick up a non-working one and convert it to electric. Lot's of them on e-bay.
http://www.argoatv.com/
Alternate:
Recreative Industries MAX
http://www.maxatvs.com/index.php?sub...ocs&link=MaxII
Old 02-22-2007, 04:47 PM
SamSam SamSam is offline
Rep: 455 Posts: 1,606
I like the idea.
Fresh water weighs around 62# a cubic foot. So, the body/hull has to have enough cubic feet of volume to displace as much weight of water as everything will weigh (hull+cart+cargo+people+ etc) plus extra so you will have free board (the part of the hull above the waterline) for safety.
I do like the idea. Sam
Old 02-23-2007, 07:47 AM
Rep: 10 Posts: 2
Thanks for the replys.
The ARGO looks like an interesting vechical, but the vehical I produce really needs to be sized as a golf cart. Our city concil just last weeked ruled a resident cant' take his John Deere Gator on the trails (or maybe it was a Yamaha Mule) although gas powered golf carts are allowed.
I'll figure out the weight I'm trying to support and go from there.
Craig
Old 02-23-2007, 03:01 PM
kach22i's Avatar
Architect
Maybe you could have a fabric tarp come out like the Bradley fighting vehicle.
Perhaps inflatable rubber raft tubes like amphibious Ultra lights use.
How about a hovergolf?
Similar to this:
http://www.hoverclubofamerica.org/fo...=504&hl=hummer
Old 02-23-2007, 04:53 PM
Similar to this:
He's limited to electric propulsion, probably because of the noise. Aren't hovercraft sort of noisy? Sam
Old 02-23-2007, 05:12 PM
kach22i's Avatar
Architect
You can make one quiet, but it's typically not done for a lot of reasons.
The problem with making a hovercraft conform to "boat rules" is that it's not a boat. For instance if there is a HP limit intended to keep wake or water born pollution limited, these rules are designed for displacement hulls not hovering hulls.
I think inflatable floats would be best for this project, always inflated.
You can't take a heavy craft be it boat or car and convert it into a hovercraft as much as I'd like to. You can make almost anything hover on ice.
The Bradley has a habit of sinking and drowing it's crew, maybe not the best model to emulate.
Old 02-23-2007, 07:45 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
Maybe if you learnt to play golf better, you wouldn't have to take such drastic action to get your golf ball back.
Old 04-09-2007, 08:29 PM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
Floating a golf cart
I suppose it means adding 'aft' to your vocabulary as well as 'fore'....
Old 04-12-2007, 12:59 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Yeah but Kach the bradley normally only sinks once! bit of a bugger finding after that - unless you can hold yer breath and drive like mad!
Golf Ball Fluid Dynamics Inquisitor Boat Design 64 12-11-2006 08:15 AM
Ya'know, like a golf ball resurrected Boat Design 27 11-09-2006 10:22 AM
Used Golf Balls mallikarjun_123 Open Discussion: All Things Boats & Boating 17 11-01-2005 06:38 PM
Cart before the horse rturbett Fiberglass and Composite Boat Building 1 10-03-2005 06:25 PM
Floating frames Morgig Boat Design 2 02-13-2004 05:03 PM
