Old 09-29-2009, 05:54 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Drogue Line Length
How long should one have a drogue line ? I can see it it would be real fun if the drogue plucks out of the wave and suddenly shutes open to grip again, especially once you picked up a bit of speed
My drogue has a few 500mm shutes after one another. I've tested in a dam with my friend (tried to) pulling it behind his jet ski. I know the drogue works fine, the jet ski didn't get away, I just need to confirm the rope length.
Regards
Fanie
Water ! Just gimme water !
Old 09-29-2009, 06:10 AM
masalai masalai is online now
masalai
Rep: 1630 Posts: 7,322
At a wild guess, having never had a need or desire to deploy one, 1.5 wave crests behind you or more... I would rather run in a direction away from the predicted path curve of the storm AND away from shore/reef/underwater obstructions... or, - - sail 'into', on the most comfortable tack, the passing front but particularly, away from lee shorelines etc done both there...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 09-29-2009, 07:24 AM
bntii's Avatar
bntii bntii is offline
Rep: 948 Posts: 636
Have you looked into the Jordan Gear?
http://www.jordanseriesdrogue.com/D_1.htm
His research showed shock loading/drogue inversion as the drogue cycles with the yachts acceleration/stall during wave passage regardless of line length.
This report is worth reading as it provides solid information on this topic:
http://www.jordanseriesdrogue.com/pd...uardreport.pdf
I have become enamored with a Jordan 'lite' set up with spectra line.
Old 09-29-2009, 07:35 AM
Fanie's Avatar
Fanie
Hi Mas,
I also have no desire or had the need to deploy one, but you never know. One may land in a situation where it can make life easier. If you cannot anchor for some reason then this has to be your anchor.
One thing I can imagine that would keep it below the surface would be to hang a weight like an anchor on it, could mean a shorter rope. The 1.5 wave length may not always be that certain distance, it's quite dark here at night I don't know in AU, but one may not always be able to see how far is what. It must work though.
Bntii,
I already made the thing, I'm not buying another.
Regards
Fanie
Old 09-29-2009, 08:36 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1786 Posts: 2,984
Why not put it on a winch that can adjust the length to suit as needed? Or just move the knot?
Old 09-29-2009, 09:49 AM
apex1
Fanie
>>>The 1.5 wave length may not always be that certain distance, it's quite dark here at night I don't know in AU, but one may not always be able to see how far is what. It must work though.<<<
Even when it is pitch black at night, you KNOW the wavelength, you must not measure.
Regards
Richard
Old 09-29-2009, 01:52 PM
Mariner
Rep: 777 Posts: 1,546
Fanie,
Good question, I don't know the answer but I'm not sure it's that critical and may be dependant on sea state. I would think putting the line on a winch a good idea. How many chutes do you have in series? Even if one rises out of the water, it would still be full, no? It would return quickly so little would be lost in terms of function if I understand this correctly. Do you have any pictures of the chutes? Are they very cupped or quite flat?
Where are you going on this epic venture you are preparing for?
Tom
Old 09-29-2009, 02:06 PM
Fanie's Avatar
Fanie
I could only test it on the fresh. The two chutes dug in immediately and never surfaced. In waves at sea however it may happen that they will pull out of a wave. This will depend on how fast the droge is pulled along and the height of the waves and your position and the drogue's in the waves.
You are going to need a winch, no two ways about it, and you will have to tie the rope before putting the drogue in the water You can trust me on this one ok, the test on the wet bike had the rope so taunt it felt like a steel rod. Didn't measure the pull with a loadcell but you can try to hold on to a big wet bike and keep it from going. I have to admit I was quite impressed.
Tom, sadly the way I feel right now I just want to get into a boat and fcuk off - anywhere - I dont care where.
Regards
Fanie
Old 09-29-2009, 05:36 PM
masalai
Fanie, no need to add a weight to keep it in the water... You will never recover it if you do.... as it will be straight DOWN - - If you must deploy, tie a light line to the tail end so you can recover without the "drogues" opening
Old 09-30-2009, 12:29 PM
Fanie's Avatar
Fanie
Hi Mas, I know about the reverse retreive method. I'm sure a winch will help regaining the drogue, unless it is something you need to get out of the water quickly.
I read the article when Richard Woods (of woods design ) was on Elipse ? in a storm and he had problems with his drogue or lack of one. I am convinced it is a nice piece of equipment to have aboard, just in case.
Regards
Fanie
Mr. Jordan's series drogue -- possible design improvements? BillyDoc Stability 3 09-02-2008 09:57 AM
Series Drogue - Stern Transom Attachment oldsalt1 Boat Design 2 02-08-2008 05:32 PM
how to make a drogue or sea anchor sigurd Boat Design 37 09-08-2006 05:45 PM
Length Over All Danielsan Boat Design 11 02-18-2005 06:44 PM
What Length? fisherman Powerboats 2 05-16-2004 11:29 AM
