| drafting machines I found this board while searching for info on elbow drafting machines. I am looking for owners manuals for the "TYPICAL" elbow branded with the ALVIN, MUTOH, K&E, and VEMCO. Any info as in links, web sites, pdf files, personal contacts welcome. The design of the machine is a part of my buying decision. Thanks. |
| I'm a parallel guide rule board guy myself. I wonder how many young people reading this think you are talking about some sort of software? ![]() Try Craig's list, it's local. So many firms threw the last of their drafting stuff in the dumpster 10-20 years ago that stuff might be found in the vintage furniture shops. The old mail order places are still selling on-line. Prices vary all over the place, it pays to shop around.
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| I have a Vemco V-track drafting machine, and Vemco's company website has a complete owner's manual for it. And by complete, I mean it includes an exploded diagram of the protractor head -- plus clear instructions for common repair and adjustment procedures. I would assume they do the same for their elbow machines....
__________________ "All one has to do is follow the plans and build in no permanent leaks." -Charles Minor Blackford, on the simplicity of building flat bottomed boats |
| Vemco elbow here. Though it sees damn little use as Cad and the plotter stand ready... |
| vemco elbow Can anyone tell me if the typical VEMCO elbow like the 3300/3500 can be rotated a full 360 degrees at the base, elbow, and head? Scales and protractor rotated 360 independantly? The on line manual does not mention that. My K&E PARAGON does NOT rotate 360 at the base. Thus the machine can only be mounted with the base on the left, so that the vertical scale is on the right pointing up. I need the exact opposite mounting with the scale STILL pointing right and up.. If the mounting rotates 360 and the other two points also rotate 360 than the unit could be mounted left or right with the vertical scale still pointing up. Any info welcome. The only variable is the head used for RH and LH. Feel free to pass this along. |
| I can tell you when I get back out to the shop tomorrow morning. |
| vemco Thanks in advance for your interest. In the meantime I am going to cut off a mounting chuck from my old head, and mount it to the existing 90 degree chuck making it a "T". In that way I can mount the vertical scale pointing to the base. The only downside is there is not enough rotation in the base to align the "0" mark on the horizontal plane. I will need to use the "(90)" degree mark instead. Not ideal but usable. |
| OK- on mine (a older Vemco broken elbow w/16" arms), the graduated bezel rotates a full 360. At any position, the bezel holding the scales may be locked to the graduated bezel thus indexing to the "O". So two locks- one on the graduated bezel and another on the one for scales. |
| vemco It sounds like it might work for me. If the base also rotates 360 then it can then be mounted to the right with the vertical pointed up torward the base. |
| K&e Quote:
| Searching for plate forming NC press machines. | vineethn88 | Boatbuilding | 3 | 09-11-2010 12:42 PM |
| Looking for drafting help | 3dig | Services & Employment | 2 | 12-03-2009 09:51 PM |
| How I can regain the dazzling appearance of my machines? | mariyadisuja | Open Discussion: All Things Boats & Boating | 29 | 01-31-2009 02:24 PM |
| Machines for pvc foam | Mihajlo | Materials | 0 | 10-11-2006 07:00 AM |
| CNC routing machines and Rhino | Kirk Hill | Software | 7 | 03-23-2005 03:35 PM |
