| Do-It-Yourself Fender I need three huge fenders to keep a 60 foot boat off a concrete pier. The commercial ones I've seen are airfilled and start at $3,000.00 each and they can be punctured. Any ideas how to make a large fender this size out of scrap or cheap but durable materials? |
| you can use truck tires or tracktor tires and chain them to the sea wall. |
Need something that floats up and down with the boat. |
| I put the fender horizontal with 2 ropes, 1 on each end. It rolls up and down with no damage to anything. They work like soft rolling pins. Or position them on the water in front of pier colums. String the lines to a pier on either side of the one with the fender in front of it. |
| Battle of the Fenders Quote:
High winds and typhoons out here in the Far East create a difficult mooring situation. |
| How about a length of hollow pipe the inside diameter of used heavy duty dump truck tires. Weld a retaining plate on 1 end, slide on 5-10 tires, weld on the other end plate. Put ropes on each end. Let it roll up and down. Could be tied to piers or the boat. Mussels and vandals have had it. Your welcome. |
| Do it the old way - with rope fenders. |
| you mean like this http://www.boatfenders.co.uk/ and clicking on the link on the bottom of the page you get another 100 fenders but no one i could find does $3K or more perhaps another thought is the tugboat style docking sideplanking? |
| does it has to be esthetic? Do you have to pull them up or is it allowed that the they be heavy? Maybe you could make a mold of a finder like form and fill it up with some kind of self expanding polyurethan mastic or synthetic foam or silicon rubber? greetz,
__________________ Daniel Peeters |
| That's a good idea. Self expanding foam is an interesting thought. So tires didn't work. Maybe you could fill them with foam and seal off the interiors and attach a nice surface for the boat's hull to "lean" on.
__________________ Signed- mackid068 _________ Sailing (n.) The art of getting wet and going nowhere slowly at great expense (it's fun though) =/\= A sailing Trekkie!=/\= |
| Bob Unless you can get the dock owner to add some decent vertical rubber ship dock buffers then I'd work on the tyres, if you cant get a good heavy tyre to do the job nothing will. I'd Work on ways of fixing the tyres in place on your boat relative to your rub rail or contact points. Forget the PVC air filled fenders they're not strong enough. I've seen some heavy closed cell foam mats that seem near indestructable that work well. Tyres can be wrapped in various materials but watch the continual abrasion on your topsides.
| Fenders Quote:
Thanks for the input. |
| Multiple ropes?
| lots of my customers use these mooring whips.they work awsome and they are not expensive.they are easy to use you will like them it makes docking easy to you can leave your dock lines hanging from them.So when you pull up you can just grab them.you dont need no hook or nothing. http://www.sailboatstuff.com/mor_morwhip.html |
