Old 04-15-2009, 05:39 PM
chappers69 chappers69 is offline
Rep: 10 Posts: 5
boat identification.please help!!!
anyone know what ive just bought??-help most appretiated!-paul
Old 04-16-2009, 01:52 AM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,317
too hard to tell from that photo. Take some front, rear and side vuews. Does it have a Hull identification Number on the transom? it should be in th eupper right corner looking from behind the boat, and be a twelve digit number similar to this ABC12345L495 or if made before 1984 ABC12345M75L. The first three letter identify the builder which you can look up at http://www.uscgboating.org/recalls/mic_database.htm
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 04-16-2009, 07:44 AM
Rep: 10 Posts: 5
hi my friend,-the only numbers are sp10216 or may be spi 0216,-i will add some pics of it before starting the re-furb.best regards and thanks.-paul
Old 04-16-2009, 04:37 PM
Ike's Avatar
Ike Ike is offline
Never seen this particular boat. From the side and front it looks like a small outboard hydroplane but the hull is a deep vee. I suspect it was built for racing, maybe a drag boat. Yes, they drag race boats too. But there appears to be a fin on the port side, so it could be a regular oval racer in one of the outboard classes. They always go counterclockwise, that is turn to the left, so the fin is on the inboard side of the turn to improve tracking and prevent sliding.
Ike
Old 04-16-2009, 04:40 PM
Ike's Avatar
Ike Ike is offline
As usual I forgot to look at your profile. Is that Plymouth, as in UK? They didn't start using Hull Identification Numbers until the late 90's so.
Ike
Old 04-16-2009, 06:38 PM
Rep: 10 Posts: 5
hello mate,-yes,-its plymouth uk.-i think you are 100% when you say it was raced in anti clockwise due to the fin,-there isnt 1 on the other side.-if i put another fin on the other side to stop me sliding on right hand turns,-would this affect handling in any way? also it was a longshaft setup and ive converted it to shortshaft.-ive been told they used to race them with 40 and 50hp,but ive just put a 65 ptt suzuki on it.-when you say they drag race this type,-do you mean having an inboard setup?-paul
Old 04-17-2009, 05:32 PM
Ike's Avatar
Ike Ike is offline
Not inboard. Outboard. There are both inboard and outboard, but the smaller ones are usually outboard. Another fin would probably help right turns. Deep vees tend to lean a lot into the turns. I hope your short shaft is long enough to get the cavitation plate below the deepest part of the transom. Otherwise you may cause the prop to suck a lot of air.
Ike
Old 04-18-2009, 05:55 AM
Rep: 10 Posts: 5
hi thanks for reply,-i cut out 5" and the cavitation plate is about 10mm below the lowest part of the hull,-do these type of boat flip or roll easy?-its the narrowest boat ive had with the biggest engine as well,-ive had lots of 13-16 foot boats with 5 and 6ft beams and they corner very well.-just a bit worried that this 1 might roll at speed
propeller identification???? toocanshan81 Boat Design 1 03-29-2009 12:12 PM
Sailboat Identification jedistud Sailboats 4 02-23-2009 12:44 AM
identification of boat design by picture ? snoozer Boat Design 0 04-27-2008 07:02 AM
lifeboat identification Evert Wooden Boat Building and Restoration 0 03-26-2008 09:16 AM
Boat identification + design input needed please ericvj Boat Design 0 11-27-2005 11:22 PM
