#31
#32
Numerous posts on this forum have been written about stray current damaging props, shafts and hulls. And now these guys want you to "invest" $1000 in a black box and two anodes that you are supposed to hang in the water. Use paint. It doesn't work nearly as good as the sellers want you to believe, but at least it doesn't dissolve your boat. |
#33
| Drydock. Also referred to as a trailer... -Tom |
#34
| BrightSpark seems to work fine and not only for recreational boating. I've meet with the guys at METS. Investing around 1500 euros (one set plus two spare anodes) is said to protect against fouling a 15 m boat for three years, thus saving an interesting sum of money in drydocking and paint, if statement is truth. I've ordered one set and I'm going to try it in my boat. I'll post here whatever results from the test. Cheers. |
#35
#36
| Or maybe BOTH Brian! -Tom |
#37
Thanks! James |
#38
#39
| I think it is called colloquially, "faith healing"... It only works if and when you believe it works...
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
#40
| Have barnacles just started to attach themselves to boats then? because they have been doing it round here for a long time. The Chemist in Pinang said to me that mixing TBT with any paint would be then an antifoul. This is not true and does not work, I tried it, it may work if you were to use some porous paint such as red lead. Last year I had bits of wood hanging off the dock for months trying out all sorts of old wifes tales. Mixing 10% 20% or 50% TBT with a cheap anti foul does nothing. It was a very exiting experiment until a dick headed Canadian police man let it go to the bottom, --no I don't now why,--- it was above his mental grasp I suppose that some one should want to learn something. If this electric machine goes wrong, you will have a blob of bronze on the end of your shaft where the propeller was last seen. If your into way out gadgets and electronic impulses,-- you may want to try playing very loud Rolph Harris records at them, alternatively its paint or scraping like the rest of us. |
#41
| Is putting a "sock" on the bottom of your boat whilst moored a possible solution? I know that this is not applicable for all boats but for small multihulls with lifting daggerboards and rudders it can be fairly easily be deployed. |
#42
| I put a sock on my props, yes it works well. |
#43
| That's a great idea! Does ANY sea life grow beneath the sock? Does it need to be a tight mesh? Do you know how it works? It seems like it might be a matter if sunlight not getting through... or maybe the food source can't get through, so no sea life can survive on the hull...or the baby barnacles can't fit through the mesh? |
#44
#45
| Well now that is a third option I had never considered... You guys certainly keep me on my toes! -Tom |
| Aluminum electrolysis prevention state of art | Patrick BLOSSE | Metal Boat Building | 8 | 09-23-2008 07:52 AM |
| Aluminum electrolysis prevention state of art | Patrick BLOSSE | Electrical Systems | 0 | 09-11-2008 03:38 PM |
| Delamination Prevention | OSM | Fiberglass and Composite Boat Building | 14 | 06-24-2006 10:39 AM |
| Rust prevention | lathamj | Metal Boat Building | 14 | 10-15-2004 07:54 PM |
