Old 06-18-2010, 12:24 PM
WickedGood
Attaching a Life Ring
Well. Just how do you guys go about attaching your 30 in Life Rings to your small boats so that they are firmly attched yet quickly accessible?
I have a 24 ft Center Console with Hard T Top
It has to be out of the way for fishing. Fly Fishing, Botton Fishing & Trolling. Anything from Trout to Giant Bluefin
Old 06-18-2010, 12:53 PM
LarryMcI LarryMcI is offline
Rep: 10 Posts: 25
We use these aluminum rail-mount ring bouy brackets:
http://www.jmsonline.net/RAIL-MOUNT-...-BUOY-BRKT.htm
The rail-mount portion may be removed for attachment to flat surfaces. The safety strap is essential! UV radiation will deteriorate the strap in a few years, but replacement Velcro straps are easy to make.
Old 06-18-2010, 01:06 PM
Rep: 1758 Posts: 1,558
Just how small is your small boat. You can use a locker if it is mounted on the side of a deck house, a rail hook like Larry, and there are several other types of racks that the ring slips into and is held in by a strap that can either be bulkhead or rail mounted.
FWIW, I've carried a horseshoe attached to a Man-overboard pole with a drogue rather than a throwing ring. Rings are hard to see in a running seaway and can drift rather fast.
Old 06-18-2010, 05:14 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...using stainless hooks like in the pic, but use two, at 10 and 2 o'clock, that way the ring stays stable and does not roll with the boat back and forward.
Old 06-18-2010, 05:16 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,349
I would just tow it behind my canoe.
Hoyt
Old 06-18-2010, 05:22 PM
mark775
Consider a throw bag; http://www.go2marine.com/product.do?...F&WT.mc_id=gb1 . It looks to me as if you are a T-boat. If so, the painter has to be 60', as I recall, and 3/8 artificial line of a certain strength. For practical purposes, if it is 3/8 artificial, it will pass. Horseshoe "rings" are not acceptable. It really starts to get funky as you put the water light on, too. That is the best water light, BTW. Everything you have there will pass if that painter is 60' and the ring is 30".
Attaching foam to a mould b_rodwell Fiberglass and Composite Boat Building 1 12-16-2008 05:18 AM
Attaching a Steel to Aluminum Hotel Lima Metal Boat Building 10 01-09-2008 03:01 AM
attaching the deck to the hull bluemarble Wooden Boat Building and Restoration 21 08-21-2006 07:07 AM
Attaching stringers to transom? mikkyle Fiberglass and Composite Boat Building 3 12-13-2004 02:21 AM
Attaching rubrails, gunwales etc Matthew Fiberglass and Composite Boat Building 3 07-21-2004 07:44 AM
